Post Tein SS-P install: "chug chug" noise from eng
Old Oct 10, 2005 | 11:08 PM
tuffCookie's Avatar
Default Post Tein SS-P install: "chug chug" noise from eng
i'm not sure if i'm gonna be able to explain this right, but here goes...
i recently installed Tein SS-P coilovers w/ EDFC on my car last weekend. since then, everytime i switch gears, it makes somewhat of a "chug chug" noise...can't describe the sound any better.
it happens every gear. the moment the clutch disengages and i give it gas, it makes the noise. my friend and i checked everything since install and can't find anything wrong. we're gonna take another look later this week, but my friend thinks it's either the engine or something loose after install.
if any of you are familiar w/ engine torquing (pull e-brake, put into 1st and quickly disengage and re-engage clutch before it stalls), it sounds similar to that.
any help or suggestions would be greatly appreciated.
Old Oct 11, 2005 | 03:39 AM
dp-_-'s Avatar
i get mine in tomorrow. I'll check for the same noise.
BTW, was the install DIY or did you have a professional install it?
Old Oct 11, 2005 | 04:34 AM
tuffCookie's Avatar
did it w/ my mechanic friend who's done these type of installs before on many cars.
installation wise, it wasn't anything difficult. everything was pretty straightforward. we referenced the DIY guide from ProStreetOnline just to make sure everything was going OK.
Old Oct 19, 2005 | 03:46 PM
-Keith-'s Avatar
Check the endlinks and stock sway bar. Also double check all the bolts make sure there tight... And make sure the springs are seated properly at the top
Old Oct 20, 2005 | 08:40 AM
mowmow's Avatar
Defintely worth checking into. I just receved my Tein SSP w/ EDFC 2 days ago.
I have to wait for my car to come out of the body shop first before I can install my
coilovers and new 18" wheels. Once I get mine installed, I check into that too.
Old Oct 25, 2005 | 05:23 AM
dp-_-'s Avatar
I don't have a chug chug noise, but I do have some sort of noise....like a steady ticking, but I'm pretty sure it's from the Header.....
Old Nov 2, 2005 | 03:57 AM
-Keith-'s Avatar
I installed mine awhile back no problems...
Old Nov 2, 2005 | 04:10 AM
dp-_-'s Avatar
eh, it couldn't be the header. There is definately something going on.....but it only happens when the wheels are spinning..........
Old Nov 2, 2005 | 11:36 AM
boostedscion's Avatar
hmm thats strange.. ask duma... he knows a lot about teins
Old Nov 2, 2005 | 03:52 PM
-Keith-'s Avatar
Did you upgrade your brakes or rotors?
Old Nov 2, 2005 | 03:54 PM
dp-_-'s Avatar
no, one of the next things that i'll probably end up upgrading
Old Nov 5, 2005 | 08:40 AM
tuffCookie's Avatar
been awhile since i've been here.
anyway, i still have the same "problem" if u wanna call it that. checked all the bolts and they seem fine.
i'm gonna try to get a sound clip of the noise. i can't think of anyway to describe the sound...to some it might sound like a "click click".
but whatever...like i said before, it only makes the noise whenever i shift.
maybe i'm going crazy...
Old Apr 13, 2008 | 08:58 PM
aetc's Avatar
anybody ever find a solution to the sound made when shifting? im also hearing the sound
evolving_machine
Feb 27, 2015 09:53 PM
XDC
Feb 1, 2015 11:56 PM
toyotaisme
Jan 10, 2015 10:24 PM
cid_mcdp
Jan 5, 2015 02:45 PM
