Underbody braces???
Old Oct 12, 2005 | 09:34 PM
JSosa's Avatar
Default Underbody braces???
Does anybody think that installing these underbraces will help my scion xa turn better? I dont know if i should spend the money and buy these braces or should i spend the money and geta set of tires and rims?
Old Oct 12, 2005 | 10:25 PM
magicmanjk808's Avatar
yeah they will help. they reduce body roll so your turns will be easier. BUT a good set of tires and rims will also help you out.
Old Oct 13, 2005 | 02:58 AM
hotbox05's Avatar
get the wheels and tires. braces later.
Old Oct 13, 2005 | 03:18 AM
gnar-de-gwar's Avatar
yeah, the stock tires suck ba***....alot of em. I spun out going through a sweeper at 60-65, and it was just sprinkler water running down the side...wtf?
Old Oct 13, 2005 | 03:24 AM
JDMJim's Avatar
I would do suspension or even try a thicker rear sway bar first.
Old Oct 13, 2005 | 04:35 AM
JSosa's Avatar
I already have koni with hotchkis and progress sway bar at the rear, im just thinking what should be the next step
Old Oct 13, 2005 | 07:59 PM
BlueBubble666's Avatar
I think that c-one makes a bracing system for the rear of the xA. At least I think it's c-one. The thing costs around $400 though.
Old Oct 13, 2005 | 08:06 PM
You're think of the rear under brace which is $373, the front one is about $20 more than the GT Spec which is $143. Personally I would get the C-One set because it's JDM and I am one big JDM ***** and C-One is one of Japan's Premiere tuners for Toyota's next to Tom's. If you have the money though and interested www.bulletproofautomotive.com can take of that for you
Old Oct 13, 2005 | 11:22 PM
deviousXA's Avatar
ScionERA
them are crack prices!......here is a BEATRUSH,Japan under brace: https://www.scionlife.com/forums/viewtopic.php?t=85637 for $171
and here is a 2 peice set from APR: https://www.scionlife.com/forums/viewtopic.php?t=85677 for $179
Old Oct 14, 2005 | 05:28 AM
....the beatrush underbrace is $8 bucks more than the c-one and that two piece set...hmmm, the front brace isnt welded?...that middle brace looks like it doesnt do crap either, the rear brace from c-one does way more
Old Oct 14, 2005 | 05:24 PM
deviousXA's Avatar
ScionERA
i must have misunderstood i though you said above that the c-one rear under brace was $373 basically the same part as the beatrush one for $171......and blue stated that it was even more than that .....i personally would just go with beatrush...JDM quality & more money in my pocket to boot plus seeing as its silver powdercoated it would go perfectly with my ride
Old Oct 14, 2005 | 05:28 PM
JDM JDM JDM!!
Old Oct 16, 2005 | 06:21 AM
ohcanada_00's Avatar
please watch the language there are little ones present every now and then.......
Old Oct 16, 2005 | 07:59 PM
Guest
Guest
Posts: n/a
I have the JiC frame brace and I love it. I just have to watch where I drive because it sits really low to the ground, and I have a 2inch drop.
Old Oct 18, 2005 | 05:04 AM
rampagesd's Avatar
i have both JIC 2 point and 4 point under braces on mine along w/ the JIC tower bar. i've noticed a difference only sucky part is that my 4 point brace gets stuck on speed bumps sometimes.
Old Oct 19, 2005 | 06:57 PM
Guest
Guest
Posts: n/a
Yeah me too. :D Dam speedbumps
Old Oct 19, 2005 | 07:12 PM
JoeBus's Avatar
Is there a link for the JIC under braces? Maybe the street cost?
Old Oct 19, 2005 | 07:43 PM
www.jic-magic.com you xB owners as always are SO damn lucky to have a HUGE aftermarket following compared to the xAs big one
Old Oct 19, 2005 | 09:24 PM
JoeBus's Avatar
Yes we are ; )
Old Oct 20, 2005 | 02:16 AM
JSosa's Avatar
I imagine its the same thing for the Xa right? considering i dont have an Xb i have an Xa
