Installing header: How hard is it to do?
Old Oct 14, 2005 | 03:15 PM
Jarrod123's Avatar
Default Installing header: How hard is it to do?
And what is the deal with getting CELs is there anything else I need to purchase and do when i install a header?
Old Oct 14, 2005 | 03:28 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
which headers??
o2 sim
Old Oct 14, 2005 | 03:31 PM
ScionDad's Avatar
Default Re: Installing headers: How hard is it to do?
Originally Posted by Jarrod123
And what is the deal with getting CELs is there anything else I need to purchase and do when i install headers?
Well, the header install requires a good set of metric sockets, metric wrenches (speed wrenches help too), jack and jack stands. An 02 sensor socket or big cresent wrench will work as well. A torque wrench will help set the torque of the header nuts (a few you can't get to with a standard torque wrench). Other than the tools, it's pretty easy.
As for the CEL. You can go to the local autoparts store and buy 2 each 18mm antifoulers (about $4.00) and do the antifouler mod on the S-Pipe sensor.
Old Oct 14, 2005 | 04:16 PM
The_Instigator's Avatar
Tip #1...MAKE SURE EVERTHING IS COLD. Let it cool down for a coulpe hours before you start!!!
I did mine in about 90 minutes with a buddy helping me out. The hardest part for me was the far left bolt on the stock manifold. I couldnt get a wrench on there and turn it with all of the parts being so close. I ended up using a 12mm socket on a u-joint and just breaking the bolt loose and then the rest by hand.
I would reccomend spraying the O2 sensors as far ahead as the night before with the WD40 and continue to spray a few more times to make sure you dont damage it upon removal. Also, dont remove the O2 until after the new header is completely installed to ensure the parts will all be room temperature. If you dont have any anti-seize coompound, make sure to get some to put onto the O2 threads so you will be able to remove it later if you ever need to go back to stock.
If you go AW, the brackets probably wont line up correctly, and I ended up removing mine altogether, but I also have an engine damper which will keep the welds at the flange form cracking. I would also reccomend removing the dipstick as it will give you some more room to work with, and if the dipstick touches the header after you reinstall it, just use some muscle to bend it out of the way a little.
Old Oct 14, 2005 | 07:33 PM
Souljah347's Avatar
the first header goes on pretty easy, expect for the far left bolt on the bottom. but finding a place for the second one is going to be a problem
Old Oct 14, 2005 | 07:43 PM
reagulator's Avatar
har har
Old Oct 16, 2005 | 06:12 PM
Diluvium's Avatar
it took me and 2 other poeple 3 hours.... basically from slacking off a bit and the bolts were too tight together... the bottom bolts are the worst to take off... also the long wait for the O2 sims to come off took awhile too
SuBSiN
Mar 13, 2015 04:02 AM
CPL_Radar
Mar 5, 2015 05:42 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
