saken4
04-03-2004, 12:12 AM
Well i bought a injen short ram intake and had it almost instaled but ran into one problem with the maf sensor. The screw holes were way off and wouldnt line up on the injen intake. So i took the intake back and they said it wasnt different from the other intake they had in stock for the xb so they gave it back and said there was nothing wrong. I ended up getting my money back but i was wondering if anyone has ran into any problems with the Injen intake on the xb scion? Or maybe my xb is just the black sheep of the fam. :twisted:
could you have possibly just had the sensor twisted the wrong way for the bolts to line up?
Munch
04-03-2004, 12:37 AM
Mine bolted right up in about 7 minutes :D
ncscion
04-03-2004, 03:55 AM
mine fits perfect ( so glad i could say that) just installed mine today. i had a similar problem and it was what stylis said. it was twisted the wrong way or something. moved it alittle and it fit just right.
scibrew
04-03-2004, 03:23 PM
mine installed in about 15min. try turning the sensor around.
-scibrew-
saken4
04-03-2004, 05:13 PM
I moved the sensor every which way and nothing worked. Even the guy at the shop couldnt get it to fit.
xAzNDeVoTioN
04-03-2004, 05:44 PM
i had a similar ordeal ... but eventually i got it to fit perfectly w/o modification. The black part doesn't completely cover the metal ... (hope you understood what i meant) ... so two corners are covered by the plastic(the corners w/ the holes) and two other corners are not covered.
Although I have an xA .. i got the Injen anyway and modified to become cold air =P
