View Full Version : Oil Change: How many miles
austin316 10-16-2005, 11:10 PM I had my first oil change done at the Toyota dealership after 4800 miles. How long should I go between oil changes?
I have used the search function but am not getting any results. (the website creator really needs to make an option that allows for you to search the titles, and not the body. Otherwise 'oil change' brings up thousands of results.)
Somnambulated 10-16-2005, 11:15 PM Your manual says 5000 miles.
I stay between 3000 and 4000. Just to be on the safe side.
Batjew 10-17-2005, 12:52 AM I did the very first at 2980, I'm sticking to the manual at 5000, but i regulary check the oil, im used to telling how dark it should be. but i'll switch to Mobil1 15,000 after my next two free changes from the dealer.
StatuSCheckA 10-17-2005, 01:42 AM I have 400 miles on my car.
I plan to do a oil change at 800 miles, which i will call the end of my "break in period"....
And I love TRDSparks! I'm just sayin tho.
FromThisSoil 10-17-2005, 03:09 AM Changed my oil at 5000 miles with AMSOIL fully synthetic 5w30 and an AMSOIL high flow oil filter.
Won't need to change it for another 7500 miles after that, just to be safe, I'm going to do an oil analysis at 4500 miles to check the contents of my oil just to make sure everything's ok.
ack154 10-17-2005, 03:15 AM I have 400 miles on my car.
Why wouldn't you wait until after 1000? The full break in period described in the manual?
Moved to M&CC.
gfcrane 10-19-2005, 01:27 AM While Amzoil can certainly be expected to go 7500 miles before changing, one should carefully consider the warranty. It clearly states 5000 miles or 6 months for maximum time/mileage between oil changes. After the warranty period Toyota no longer cares. If, in the unlikely event you have an internal engine problem, some indication of service will be required for Toyota to fix it under warranty. 7500 miles would probably be siezed upon immediately to avoid warranty repairs.
BOOST4Doors 10-28-2005, 04:44 PM 3000 for regular oil (especially for the southern states where summer heat is a major factor)
5000 for synthetic
-period-
midtowndesi 10-28-2005, 05:38 PM I am not sure if this is material from the manuals or not, but here is the schedule that a Scion Dealer in Manhattan has posted:
http://www.scionofmanhattan.com/Service-Pricing.aspx
(it includes oil changes, tire rotation, and other maintenence related tasks)
If you need a good laugh, also take a look at their pricing for the service... It's hilarious.
- sh00k
jallamas 10-28-2005, 05:46 PM What BOOST4DOORS said!Period! :bow:
DisneybB 10-28-2005, 06:29 PM 3000 for regular oil (especially for the southern states where summer heat is a major factor)
5000 for synthetic
-period-
3000 or 3 months which ever is first
5000 or 6 months for synthetic
It'll keep you engine purty!!!
hotbox05 11-03-2005, 11:03 AM people still use non synthetics?
ScionSpouse 11-04-2005, 06:27 PM My wife and I have put nearly 900,000 miles on a variety of cars, and have never had an oil related problem. Just sold a Previa with 208,000, and the engine was running like a clock. Oil and filter changes every 5000 miles.
HeathenBrewing 11-04-2005, 06:59 PM Im only at 156 miles so far.
My first oil change will be at 1000.
From then on, every 3500-4000 or 4 months.
Any extra $20-$50 per year in oil changes is really cheap insurance IMO.
legendaryxb06 11-04-2005, 07:04 PM 3000 for regular oil (especially for the southern states where summer heat is a major factor)
5000 for synthetic
-period-
werd
lalagimp 11-06-2005, 01:57 AM So I guess it's safe to assume then that the dealers should/would be using synthetic when they change your oil every 5000 miles? :p
gfcrane 11-06-2005, 11:58 PM Wrong. Dealers only use synthetic if you request and pay extra. Otherwise, most dealers buy dino oil in bulk from low bidders. This oil is usually name brand but hardly premium stuff. The only exceptions would be those, such as Porshe, Corvette, or MB requiring this oil from the factory.
emiller 11-07-2005, 12:03 AM Just make sure you go no longer than what Scion recommends cause like someone said if you have a problem they will use that to avoid paying for the repair. Hot weather, dirt roads, and lots of short drives then you need to change it sooner.
lalagimp 11-07-2005, 12:56 AM I wonder why Scion says 5000 miles, and it's on regular oil. :eyebrow:
mikee1680 11-07-2005, 12:58 AM there's no need to spend so much money. unless you have a turbo or a supercharger.
boostedscion 11-17-2005, 04:38 AM yea i got my first at 5020
TIZZO 11-17-2005, 05:04 AM oil changes depend on alot of variables, driving habits, climate, maintenance, type of gasoline used are just a few, 3-5k is just a guide, pull out the stick and take a look at it yourself, if its golden brown its clean but if its black thats no good, regardless of what the mileage is... :no: :no: :no:
markbvt 11-17-2005, 04:07 PM Dino oil has gotten much better over the years, which is why a lot of manufacturers recommend 5000-mile intervals even with nonsynthetics.
But personally, I don't like the idea of going that long on nonsynthetic oil, especially during break-in. I did my first oil change at around 300 miles, second at 1000, third at 3000. At 5000 miles I'm going to switch to synthetic, then maintain Scion's recommended 5000-mile interval.
I'm going to make it very clear to my dealer that they are never to touch my oil drain plug or filler cap on the rare occasions I bring the car to them for anything. I'm even considering cutting them out entirely -- I've got a mechanic I trust who can do the recommended maintenance that I can't tackle myself.
--mark
7500 mile oil/filter change. Mobil 1 Syn and Toyota Filter.
boostedscion 11-26-2005, 09:20 PM free oil changes for 15k
halebop 12-06-2005, 04:12 PM 7500 mile oil/filter change. Mobil 1 Syn and Toyota Filter.
does that mean if you were to have an engine related problem (and hopefully you never will!) that you won't be covered under warranty? i know scion says oil changes every 5K miles. i wonder if an owner goes 5,080 (for instance) between oil changes if that voids the warranty. i'm thinking it would...
