Alphawerks header and CC S-pipe Help!
Old Oct 18, 2005 | 03:57 PM
400amonth's Avatar
Default Alphawerks header and CC S-pipe Help!
Ok so the place that installed these pieces said that they had to grind down another gasket laying around the shop to make it fit together. They did use the spring bolts but there does not seem to be nuts on the side of the spring bolts front side. They said the spring bolts thread through the header and do not need nuts/washers and must be flexible.
I ask because I swear I smell fumes from the front of the car and wonder how good the seal really is and this bolt question is also on my mind. Anyone have a perfect fit gasket idea? Also a little ____ed because the side mounts did NOT line up either on the header to the oe mounts so those are not being used. They said they may be able to cut the brackets to make it work but I held off.
Thoughts?
Scott
Old Oct 18, 2005 | 04:10 PM
The_Instigator's Avatar
I took off the brackets for my AW header because I didnt like the way they fit. As far as the S-Pipe, I should get mine later this week and Ill let you know how it goes.
Old Oct 18, 2005 | 04:16 PM
FYI, the pipe will probably smell as it gets hot and burns off any residue and greasy hand prints that may have been on there. By grindiong the gasket, are you talking about the donut gasket at the header or at the s-pipe to mid pipe connection (im not sure if there even is a gasket there)?
Old Oct 18, 2005 | 09:37 PM
400amonth's Avatar
The donut between header and S. You would think some one would have addressed this by now.
Scott
Old Oct 18, 2005 | 10:29 PM
I bought a new donut gasket at the dealership already so Ill let you know if I have any issues when I install it.
Old Oct 19, 2005 | 01:08 AM
400amonth's Avatar
My factory was fine but did not fit well. Why did you buy another one?
Old Oct 19, 2005 | 03:50 AM
I got a new one just in case the original has gotten crushed from the initial header install. I didnt want to have to get under the car again if it turned out the original one was leaking.
Old Oct 20, 2005 | 03:09 AM
lvnurs9's Avatar
those alfawerks headers seem to be an issue with everyone
i have the megan and everything fit perfectly
Old Oct 20, 2005 | 04:54 PM
hahaitzskippy's Avatar
i only used one of the lower side mounts
the passenger side mount is the only one that fits.
as for the smell. if your header are new then its jus the metal burning and conditioning and stuff. no biggies. the smell will go away.
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
stayintrucha
Regional - Pacific South
Aug 27, 2015 05:01 PM
