Turbo back exhausts for the TC
i searched and i couldnt find anything:
but is there any turbo back exhausts for the TC out yet?
If not what are all you Turbo TC guys running?
How bout any custom exhausts with turbo vids or sound clips?
Thanks
Mark
Thanks
Mark
yah i was told either to go dual 2.5 with y pipe or go 3 inch but i couldnt find a kit for 3 inch so i figured i would ask all of you's at scion life. Is there a 3 inch tho
An EVO is also a turbo built motor made to handle a lot more boost than a tC. Im not saying a tC cant handle a lot of boost, but at that level, youd be worrying about things a lot more important than exhaust...like full custom engine management, custom fuel system, clutches, axles, etc. For the kits out now, 2.5" is just fine.
Originally Posted by Stock
someone who has a evo they said for optimum(sp?) power for a turbo run a 3" manifold back exhaust
Originally Posted by nester
Originally Posted by ZPIracing
ZPIZPIZPIZPIZPIZPIZPIZPIZPIZPIZPIZPIZPIZPIZPI...............Sorry it is late
Turbo back would likely indicate an s-pipe back exhaust that would remove the cat or replace it with a hi-flow unit. Cat back would require cutting the factory exhaust off after the cat and welding the new exhaust sytem back in. Many times sytems labelled as "cat back" are really an "axle back" that is a direct bolt on that would connect to the exhaust midpipe near the rear axles. While they are "cat backs" because they are after the cat, they should be advertised as axlebacks, unless they are truly a cat back like Creative Compacts makes.
