xa speaker size
Old Oct 19, 2005 | 09:47 PM
vampirecowboy's Avatar
Default xa speaker size
friend of mine is upgrading the speaker system in his 06 xa that came with the160 watt pioneer setup .... so far hes got a bazooka party pack subwoofer hooked up and we know the front doors are 6 1/2 components but we are baffled at what size is in the back doors some places say 5 1/4 some say 6 1/2 some dun even tell ya what the size is so any help we can git on this matter will be very much apreciated :D
Old Oct 21, 2005 | 04:45 PM
Oni-Haya's Avatar
the back speaker is 5 1/4. However, it can handle some 6 1/2. It all depends on depth.
Old Oct 21, 2005 | 07:19 PM
koan's Avatar
Sure the front is 6.5? I took off the door and measured my `05 and i looks liek 5.25 to me. I got the scosche adapters too and I dont see how they would fit 6.5" either...
Old Oct 25, 2005 | 10:56 PM
thanks ya'll we have been told 6 1/2 wll fit both locations but very few companys offer ones that will fit matter of fact circuitcity bestbuy and crutchfield show 6 1/2 for both wich seems odd when shops say it could be either and thats even a shop owner that has a 06 xb .......if it is 5 1/5 components and 5 1/4 out back what would ya'll suggest installing that ya'll know fits these cars ?
Old Oct 26, 2005 | 12:20 AM
randomsuper's Avatar
6 1/2's fit fine in the front and back. if you pull out the door panels and speakers and lower the windows, you'll see you won't have any issues there, so you have more than enough room to mount anything you could possibly want. the only problems you could face are if you use 3 way speakers with a tall tweeter because it might touch the door panel and sound crappy. my suggestion is to make some brackets out of mdf and mount a component set up front and a nice 2 way speaker in the back. just make sure that if you keep the stock headunit you use speakers that are very sensetive since you won't be feeding them much power. otherwise, you'll lose a lot of the base output. and if you can, sound deaden the doors because it makes a difference you won't believe. hope that helps.
Old Oct 26, 2005 | 12:24 AM
and be sure to check out crutchfield.com. they have pretty decent guides as to what fits. even if you choose not to buy it there, you'll know it'll work for your application. and read the reviewsbecause sometimes they'll have some pertinent info.
Old Oct 26, 2005 | 01:16 AM
thanks folks this helps alot
Old May 17, 2006 | 06:36 PM
Sliphorn's Avatar
Wow! OLD POST!
But a good one! Found it by searching. Now, this is what I've been wondering, too. Randomsuper, you're aware that Crutchfield.com doesn't specify anything large than 5.5 in the fronts? It's all kind of confusing. Also, what exactly is MDF? How does one go about fabricating mounting brackets using it? I really would like to know, because I'm sooooo sick of my factory speaks I might vomit. soon.
So, any definitive speaker size solutions for the XA?
Sliphorn
Old May 17, 2006 | 07:11 PM
mdf is like plywood only much more stiffer and actually stronger most of ya aftermarket speaker boxes are made of mdf multi density fibre board all i have in the past messed with particle board speaker boxes that wound up literally in pieces so my suggestion all boxes for sub and baffles for speakers be mdf as for me and friends situation we dont have the speakers yet but still lookin at kicker and sony stuff wish us luck hes sposed to have the money av to start gittin stuff in few weeks should runn 500-600 bracket for everything and yes we are gonna use the factory head for a while atleast till he can afford a decent aftermarket head
Old May 18, 2006 | 08:16 PM
Sliphorn's Avatar
Wow, RandomSuper...That's heinous. I just read the post. What's the latest?
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
blh72
Jan 31, 2015 03:41 PM
