Volk Owners: Help!
Old Oct 20, 2005 | 06:36 AM
nineohtoo's Avatar
Default Volk Owners: Help!
First off, i'm using TE37's, if that helps any. Seems like they're not the only ones to utilize the same mounting hole sizes.
So my local wheel shop used my stock nuts a while back, and one day recently I decide to use some tuner style nuts that would match the car a little better, and look nicer. So I bust out the wrench, and what do you know? Ish doesn't fit lol. I asked the guys at the shop how they got the wheels on and off, and they said they must have used something with a very thin sidewall. They recommended sears, but sears didn't have anything.
So my question. What wrench do you guys use to take off your wheels? This isn't only for my nuts, because if I get a flat I'm screwed. Any help would be greatly appreciated. Thanks for reading.
Old Oct 20, 2005 | 07:07 AM
fsr20det's Avatar
you should be able to use a socket for a rachet. that is what i used before in a simila situation. the side wall should be thin enough to clear. i would suggest getting rays lugnuts. pricey but you get quality lug and locknuts and some jdm rim bling.
Old Oct 20, 2005 | 07:10 AM
HoTBoX009's Avatar
My friend had the same problem... he went to Pep Boys and bought a foldable cross bar. It has socket attachments that are thin enough to fit it. Sorry, i cant find any pics of it.
Old Oct 20, 2005 | 07:44 AM
hamads's Avatar
um i use a 1/2" breaker bar with swivel head...with the key for the lug nuts it fits easy im running ce28's though so i got plenty lug room
Old Oct 20, 2005 | 02:13 PM
GrantR's Avatar
My TE37's for my MR2 had the same problem. It doesn't help that the lugnuts provided with the wheel are 19mm. I went to sears and fished around until I found a narrow enough sidewalled socket to do the trick, but the clearance was so narrow to the lug recess walls that it kinda scratched up the paint a little.
There are two solutions:
a) once you get a socket that fits, wrap the socket with electrical tape to protect your paint.
b) put the 19mm lugnuts on a shelf, and use 17mm lugnuts instead. <---- this was my solution.
Old Oct 20, 2005 | 03:57 PM
Dewmerz's Avatar
http://www.tirerack.com/accessories/tools/sockets.jsp
You should be able to get a set locally at Americas Tire.
Old Oct 20, 2005 | 09:38 PM
tinybigrig's Avatar
snap on thin wall 19mil socket, thinest you can buy
brent
Old Oct 21, 2005 | 07:45 PM
greg_jspec's Avatar
Volk lugs only way to go. worth the money
westsype
37
Jan 16, 2008 06:34 AM
XENITH
24
Jul 26, 2005 08:53 PM
dieselstation
14
Jul 1, 2005 07:52 PM
Crab_Spirits
49
Oct 29, 2004 11:10 PM
KAuss
13
Apr 5, 2004 06:46 AM
