scion security in switch panel
Old Oct 20, 2005 | 08:46 AM
toupy's Avatar
Default scion security in switch panel
I notice a lot of cars I've seen has the scion security on the switch panel that shows its arm & the glass sensors, I got the scion security but they didn't install one on there, does anybody else got it like me? or do yall have it installed on the switch panel too? cause if so, I'm 'bout to go back and get my switch filler!! plus the illumination switch looks lonely by itself.
Old Oct 20, 2005 | 09:33 AM
Jowie's Avatar
Default Re: scion security in switch panel
Well, if you have the LED on the center console, thats just the engine immobilizer. If you don't have the switch panel LED/GBS module over by the power mirror controls, you may not have the add on Scion Security. If you did get it, you should have gotten an additional manual for it.
Old Oct 20, 2005 | 11:27 AM
ack154's Avatar
I didn't get an additional manual... but if you don't have that on your panel, you need to go back and be sure they even installed it. If they did install it, take it back and insist that they forgot something.
Old Oct 20, 2005 | 06:54 PM
toupy's Avatar
well i think i know they installed it because i got the key with it? the scion security key, and they gave me another security, the auto-mate's anti-theft system which was free along w/ the scion security.. but i guess ima go back to them and be like wheres my switch panel led/gbs module! haha.. thanks guys
Old Oct 20, 2005 | 06:57 PM
ack154's Avatar
Those keys are standard. You get the keyless entry by default... but the security is just an add on that you really only see with that panel being there.
Try this: Get in your car. Lock it with the key. Wait at least 30 seconds (important) - then try to open you doors.
Or from the outside... lock it, wait at least 30 seconds, then tap on the sunroof with your key. If you tap hard enough, it'll set the alarm off.
But I suspect that you don't even have it.
Old Oct 20, 2005 | 07:28 PM
Jowie's Avatar
A surefire way to see if its in your car, check out the installation pdf:
http://www.trdsparks.com/install/08586-21811inst.pdf
On page 5, follow the steps to remove the glove box under panel(really easy, no tools required), then look up toward the firewall for the two security system ECU's. They will be on a single bracket, to the right of the main ECU for the car. Its kinda tucked way up in there, see figure 8-4 on page 18. This is where you need to go if you want to adjust the sensitivity of the Glass Breakage Sensor as well...
Old Oct 21, 2005 | 05:42 AM
toupy's Avatar
I called up my dealership today and the guy told me the led/gbs switch filler depended on the distributor of the car, since I'm from texas my dealership said that all the people from texas, arkansas, oklahoma, & around here(state wise) were distributed by the same company (forgot the name) and he said that it just depended on the distributor.. I really don't know LOL
I will try this tomorrow and see how it goes, thanks Jowie!
Old Oct 21, 2005 | 05:44 AM
toupy's Avatar
wouldn't that scratch up my sunroof?, sorry for the double post.
Old Oct 21, 2005 | 06:50 AM
bBlover's Avatar
Press and hold the panic button and if it doesn't work then ya don't have it.
Old Oct 21, 2005 | 04:16 PM
toupy's Avatar
this does work, and also ack i did tap my sunroof and nothin happen.. i locked my doors, stuck my hands in my window unlock the car manually and open the door and it does not come on..
Old Oct 22, 2005 | 02:55 AM
ROBOTCRANKIT's Avatar
Scion Driven Girls
Then you don't have it. My mom's xA has scion security and whenever we leave it locked with the windows down and I go out to open the door and get something, the alarm goes off.
Go back to your dealer and tell them they forgot to install it.
Old Oct 22, 2005 | 07:55 AM
bBlover's Avatar
You are supposed to tap the driver's window in the middle. Not the sunroof
Old Oct 22, 2005 | 07:49 PM
toupy's Avatar
^^ will do....... I'll call them up & ask to adjust my GBS and if I don't have it they better offer me something cause i'm not payin an extra 30 bucks for the scion security on my payment when i don't even have it! >=\
Old Oct 23, 2005 | 05:21 AM
bBlover's Avatar
Ur welcome. What robber would break in through the sunroof? Not a lot of space. (Not trying to make ya feel stupid!!)
jayz0302
Jan 18, 2024 09:53 AM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
randode
44
Jun 29, 2004 04:19 PM
McG_XB
22
Feb 10, 2004 09:53 AM
