Component speaker question!!!***************
Old Oct 21, 2005 | 04:30 AM
binhbinh's Avatar
Default Component speaker question!!!***************
Where do you guys mount the crossovers for component speakers???
and what gauge wires should i use to hook up the tweeter and speaker?
Old Oct 21, 2005 | 04:52 AM
randomsuper's Avatar
the gauge of wire you need should be listed in the manual. as for where to mount the crossover, mount it where it won't be seen, like somewhere in the trunk. i hid mines underneath my false floor with some double sided tape. i know the manual will say to mount it as close to the speakers as possible but it will work just fine no matter where you put it.
Old Oct 21, 2005 | 05:00 AM
binhbinh's Avatar
could i use double sided tape to stick it near on the door? or how should i mount them?
Old Oct 21, 2005 | 01:26 PM
violent_b's Avatar
I put my x-overs in the kick panel and ran 16 ga. wire through the door. that way the x-overs won't get wet.
Old Oct 21, 2005 | 01:45 PM
SCI_TC_GUY's Avatar
I mounted mine on the inside of my door panel.....like them there.....
Old Oct 21, 2005 | 06:28 PM
installerguy's Avatar
mount the crossover under the seats and run 12ga. wire to the speakers.
Old Oct 21, 2005 | 07:13 PM
SCI_TC_GUY's Avatar
as long as they're actually mounted somewhere and not just sliding around it'll be ok....and as long as water or anything won't get to them
Old Oct 21, 2005 | 11:00 PM
binhbinh's Avatar
Is it easy to get the wires to the door?
Old Oct 22, 2005 | 11:42 AM
SCI_TC_GUY's Avatar
not too bad.....gotta run it through the boot in the door jamb.... you'll havta run wires in there to get to the speakers anyway (as long as you're amping the components.....
Old Oct 23, 2005 | 08:23 PM
mowmow's Avatar
My MB Quarts Premium crossover was mounted behind door panel. with a bracket to hold it in place., pretty clean didn't block the power windows at all. Did pretty much the same thing for back too.
Old Oct 23, 2005 | 09:41 PM
nfiniti9's Avatar
rofl, 12ga for any installation. you know, 9/10 installers swear by really thick speaker wire but 10/10 cant tell the difference. how you run the wires, the quality of the speakers, the power of the amps, all determine the size of the wire you need to keep from losing audible signal. most people dont need more than 14-16ga.
Old Oct 24, 2005 | 04:40 AM
binhbinh's Avatar
so what gauge wire should i use them? And is it also easy to install components because i dont want to pay 75 dollars to install them.
Old Oct 24, 2005 | 05:58 AM
it can be a real pain and running all that wire sucks. if i could have payed someone
$75.00 to do it for me, i would have. unfortunately i was dead broke by then so i had no choice. if you aren't positive you are up to the task, pay to have it done. that way you won't have your car in pieces while you figure out what you need to do. my car was apart for over a week because i kept running into stupid noobish problems. i wouldn't have been able to get it done at all if i didn't have my buddy helping me out. but then again, i ran 2 sets so it was double work and a lot of customization to get everything to fit just the way i wanted. sorry about the negativity but sometimes a reality check is a good thing.
Old Oct 25, 2005 | 03:03 AM
binhbinh's Avatar
sorry double post
binhbinh's Avatar
If i get a 4 channel amp. I would run 2 channels to the rear. Would i then run the other 2 channels to the front speaker and the tweeter?
p.s. this is for factory speakers
bootlgr
Jan 26, 2016 01:22 AM
Scionxa180
Mar 13, 2015 04:39 AM
Erickdimas7
Scion tC 2G ICE & Interior
Jan 16, 2015 03:41 AM
rolex87
Oct 17, 2005 01:00 PM
TOY_bB
Dec 15, 2003 07:41 AM
