Adjusting Headlight direction
Old Oct 21, 2005 | 06:55 PM
Dubcplaya069's Avatar
Default Adjusting Headlight direction
I have a tc and just got some luminics and I wanna adjust them a little bit so they are pointing more straight then down at the road. Sorry im trying to word this the best I can. I heard you have to like turn a screw or something, can someone help me out?
Old Oct 21, 2005 | 08:03 PM
can ne one help??? I wanna do this before i go out driving. I want to make them point more upwards instead of at the ground please ne one?
Old Oct 21, 2005 | 08:06 PM
maximus96's Avatar
there's only vertical adjustment on the stock housing. look behind the headlight and you'll see a silver, quarter sized plate with a 8mm bolt on it. twist that to adjust.
Old Oct 21, 2005 | 08:17 PM
freeflowing's Avatar
your running luminics >omg> man be careful with using that type of bulb. i personal read a couple of horror stories about using that bulb witha stock harness. just ask breakaway a fellow scionlife member
Old Oct 21, 2005 | 08:19 PM
hunterUnknown's Avatar
ahh good to know about the adjustment.
also, i hope you dont have luminics high beams. they suck. i put my stock ones back in, and it was a world of difference.
Old Oct 21, 2005 | 09:47 PM
7thgear's Avatar
just upgrade your wireharness for like $20 (plug n play) and luminicsdirect.com. it can hold up to 100w. tc can only hold 51w while the hyperwhites are at 55w. only 4w difference but it does burn the wire harness. i don't know why silverstars doesn't do it when it is rated at 55w. i'm running them in there with stock wire harness.
Old Oct 21, 2005 | 10:31 PM
pillage's Avatar
i've had mine now for a while and have not had any problems.
Old Oct 21, 2005 | 11:01 PM
maximus96's Avatar
and remember kids, park 25' away from a wall on a flat surface, and the top of the headlight pattern should be 2" below the height of your headlights.
evolving_machine
Oct 21, 2023 01:16 PM
Pkupman_77
Dec 30, 2014 09:10 PM
Opr8r
24
Jan 13, 2004 09:26 PM
