Need opinions on eD products + Help with setup Eu-600
Hey there guys and gals. Ive revised my setup. Ive already purchased the following:
Audiobahn A4601T 4 Channel Amp
2-Channel Class A/B Amplifier
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz-40,000Hz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz-750Hz
Variable 18dB Low-pass Crossover: 30Hz-120Hz
Bass Boost @ 45Hz: 0-18dB
Subsonic Filter: 20Hz-50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit, and Overload
Cooling Fan
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Nickel Plated Block Terminal
RMS Power Ratings:
75 Watts X 4 Chan. @ 4 Ohms
105 Watts X 4 Chan. @ 2 Ohms
210 Watts X 2 Chan. @ 4 Ohms Bridged
Infinity Reference 1001T Component Tweeters
Frequency Response (Hz) 2500 - 21 kHz
Model 1001T
Recommended Power Range (watts RMS) 50
Sensitivity (dB) 91
Tweeter Type Edge-driven textile-dome tweeters
UnitOfMeasure Pair
Peak Power (watts) 150
Speaker Size (inches) 1
Impedance (Ohms) 4
Crossover Included Yes
This is all going to be set up with 50 Sq. Ft. Fatmat and KnuKonceptz 4 Channel Amp Wiring kit. Ive already purchased MDF baffles as well. The Add-N-Amp harness will be on its way in a couple of days, giving me RCA outputs.
Now on to the big stuff. I am taking a hard look at eD's Eu-600 for my tC. I will use the 1001T's in the front for the soundstage, with the supplied crossover. Now ive heard great things about eD, but can i live off the bass for a couple of days until i get money to get my sub setup? Is it better than stock? How good does it sound?
Tell me ANYTHING, im ready to order =)
PS: I plan to run the entire system at 4 Ohms, however, whats the difference between mono and stereo in the Ohm specs?
Eddy
THD: 0.02%
S/N Ratio: >100dB
Cooling Fan
RMS Power Ratings:
Model 1001T
Sensitivity (dB) 91
UnitOfMeasure Pair
Impedance (Ohms) 4
Eddy
SpaceCaptain
May 11, 2015 06:24 PM
carid
Jan 22, 2015 12:49 PM
