sub trouble
Old Oct 24, 2005 | 10:48 PM
PlayinWithFire's Avatar
Default sub trouble
I have 3 10" w6's in my car and they have been workin pretty well up until now.. i run the bass at a reasonable level, not excessive but enough to feel a lil bump, and on occasion the bass just stops working... its not that theres not enough power cause my car has like 13.0-13.4 volts when this happens... it seems like everytime i bring it back to tweeter it works fine and then it will just kick out again... i am upgrading the alternator in a few weeks or so, do u think this will solve the problem? if not do any of u have tips?
Old Oct 24, 2005 | 11:02 PM
jallamas's Avatar
The voltage is ok! Check all connection, and maybe add a cap.
John
Old Oct 24, 2005 | 11:04 PM
i gotta 1 farad monster cap... i dunno ill turn off my car sit for like 10 minutes... turn it back on and its up and working again... this really sucks at shows when u cant play ur system, people think ur a poser
Old Oct 24, 2005 | 11:26 PM
jallamas's Avatar
Thats weird, I would still check all connections! I am sure someone else will have a better idea or suggestion.
John
Old Oct 24, 2005 | 11:29 PM
BUMP
Old Oct 24, 2005 | 11:43 PM
dredge38's Avatar
make sure everything is wired up correctly i know that messes with stuff
Old Oct 24, 2005 | 11:47 PM
bluenjsciontc's Avatar
ok you have a broken power connection somewhere, all becasue your reading the right voltage doesnt mean crap ...i learned, if your sub cuts in and out and after a few minutes it turns back on, you have a bad connection somewhere , start under the hood and head back to the cap then to the amp and redo everything ...like reconnect all the ends, will work fine after that and wont give you anymore trouble, where did you ground your amp to?
07tcscion
Oct 8, 2015 05:42 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Chrono
Aug 25, 2015 05:59 PM
iFangy
Aug 13, 2015 05:10 AM
