View Full Version : Disadvantages of 18 Inch Rims on a tC.
StatuSCheckA
10-25-2005, 08:20 PM
I am in the market for 18's for my 06 tC.
A few people told me that it can Lower your 1/4 Time, and all in all, slow your car down.
What is the facts behind this. Also, Will it affect the Odometer, or anything...
Please Tell my the Negative side of having 18" rims?
Although I am pretty Set on getting some!
Thanks.
I already have a TRD drop by the way.
ack154
10-25-2005, 08:22 PM
Well the slower times and such would be if the wheels are heavier than the OEM ones. You'd be adding more weight... which will slow you down.
As for the odometer, as long as you keep the same rolling diameter, you'll be fine. I'm sure someone here knows how to do the conversions and can tell what would be equal to the OEM stuff.
eXciteBox
10-25-2005, 08:27 PM
i dont know if you want to take this into consideration, but on my xB i hve had both 18's and my current 17's and the 17's handle soooooo much better. just something to consider, just trying to help :D
The_Instigator
10-25-2005, 08:30 PM
Ride quality will likely be worse with 18s with the shorter tire sidewall as well. Tires are also generally more expensive.
eXciteBox
10-25-2005, 08:46 PM
true, i paid only $75 a piece for my falken ziex's
flintTC324
10-25-2005, 08:59 PM
I have 18" FN01RC's on my tC. things to look for in wheels when upgrading are:
1) check the weight of the wheel, lighter is better.
2) the offset. Stock tC wheels are 17x7 with a +45 offset, you want to go like 18x7.5 with a +35 offset, or in that area.
3) also a lot of people like forged wheels, which are more expensive than cast, and multipiece is also more expensive than single-piece.
Some excellent wheels are: Gram Lights, Volk Racing, RH Evo, Racing Hart, 5Zigen, DPE Engineering, SSR, HRE (if you want to spend A LOT on wheels that is). Also Konig and ADR are inexpensive and popular.
if you get the right wheels, (and tires of course) your handling should definetly improve, but probably at the cost of ride comfort. Usually thats about all you are gonna sacrifice though. Just stay away from anything too heavy.
StatuSCheckA
10-25-2005, 09:37 PM
The Toyota 18's Upgrade are: {225 / 40 / 18}.
I Plan on getting the same specs on my aftermarket 18s.
I believe that will be the same Circumference as our stock 17's.
BTW, anyone know how much the STOCK rims and tires weight?
Thanks so far guys.
daggerSLADE
10-25-2005, 10:12 PM
goin from 215/45-17s to 225/40-18s .. theres a height difference .. the stock tire size is 24.6" .. the upgrade size is 25.1" .. half an inch difference .. i think thats a moderate difference .. if you went from 215/45-17s (24.6") to 215/40-18s (24.8"), its more reasonable .. i dunno .. does it make that much of a difference? im not sure .. but when i upgrade to 18s .. im prolly gonna go w/ the 215's instead of 225's .. yeah i know they are slightly thinner .. it would help w/ the odometer/speedometer reading .. and well .. take care of the other issues .. hope i could be of some help
StatuSCheckA
10-25-2005, 10:33 PM
Ya, I am buying a Package through WheelMax.com, I'm a returning customer.
It looks like they will only offer me 225-40-18.
But my theory is that if Toyota offers this upgrade, it can't be that bad for the car....see what i'm sayin. I think it really comes down to the weight of the Rims/Tires.
StatuSCheckA
10-25-2005, 10:42 PM
NEW QUESTION: The Rims I want have a 45 Offset, what does this mean for me?
EDIT: They are also 18x7.5
daggerSLADE
10-25-2005, 10:49 PM
the 45 offset will appear the same as stock .. a 35 offset will sit out more .. which is preferable .. if you upgrade .. you need to get a smaller offset to bring the rims out a bit more .. im most likely upgrading to a 18 X 7.5" rim w/ a 35mm offset .. and im most likely buying a set of Bronze Enkei RSV rims .. w/ Pirelli tires .. i like the pirellis i have now .. if they dont cost too much more then the tires they would offer in the wheel package .. im gonna go with them .. by the way .. the Pirelli PZero Neros are the upgrade option w/ the tC for the most part .. they also offer yokohamas too i guess ..
HKSpeed
10-25-2005, 10:55 PM
Checkout this handy site for tire measurement comparisons.
http://www.miata.net/garage/tirecalc.html
45mm offset is okay if your wheel is no wider than 7.5 inches. any wider and you risk rubbing the inside of the wheel/tire with the suspension.
apexjr
10-25-2005, 11:12 PM
I went with pretty much the widest tire I could come up with for my 18s. For tires I looked for the best wet and dry combination tire. For me that was the PZero Nero M+S... I am continually blown away how little sliding in the corners and how much stick there is going 3/4 throttle in the wet!
As for the weight of the wheel. It really only matters much during acceleration and stopping, and its not a ton. I read an article of a guy with light weight 15" race rims on his miata going around Laguna and lost control of his car and damaged a rim. Rather then waste the money he spent on the track day he tossed on his nice heavy 17" chome rims and went around the track. He fully expected there to be huge difference in his time, and there wasn't.
His main point, 90% of your time is the driver, the rest is the car. So buy what you like and just drive it.
rolloutrs1
10-26-2005, 02:25 AM
hate to be off topic but i guess this is somehow part of the topic. does anybody know the disadvantages of having low-profile tires in the winter time?
shawn30
10-26-2005, 04:33 AM
i dont think profile of the tire....its the tread of the tire
an all season tread would probably be a little harder to find in lo pro's tho
trdsparks
10-26-2005, 02:43 PM
The diameter of the 215/45/17's is 24.6 in but not all tires that size are that same diameter. It will also depend on tread depth. I've seen a 225/40/18 that was 24.6in but I forget what company but i found it on tire rack. Generally a 225/40/18 is 25 in. in diameter but your car will never notice the difference. You would have to be goin atleast 100mph to see any change. Then it would only be something like 2 mph.
Now you could try to go with a 215/40/18 but they're aren't wide enough for the rims. Yeah they'll go on but they aren't safe and you have a greater chance of damaging your new wheels. True light weight wheels are expensive. You can try looking into Volk's or maybe 5Zigen. Another thing you need to look for is tire weight as well. Not all tires that are the same size weigh the same.
If you are turely concerned about weight then go smaller. If you aren't taking your car to the track then I wouldn't really worry about it.
Revilo
10-26-2005, 03:02 PM
what is the weight of the OEM wheel by itself? anyone knows?
(if nobody knows, i will do it, but if somebody already did the job, please answer me)
trdsparks
10-27-2005, 01:16 AM
the 17's are 19.5 lbs
the 18's are 20.5 lbs
Kilo6_one
10-27-2005, 01:53 AM
well considering most new cars with the exception of most domestics are comming stock with 18"s and even 19"s and i dont think that is an issue with those. techinically you could say the Tc has 18" wheels stock even though its an option....if that makes sense
blastedat9
10-27-2005, 02:32 AM
*whips out glasses and graphing calculator*
according to my calculations, if the stock tires are 24.6 inches in diameter and you're running tires 25.1 inches in diameter, then when your speedo reads 60 mph you'll actually be doing 61.2 mph. so basically the diff is negligible.
there would be a slight loss of accelleration. the weight thing isnt that big of a deal really, even if it is rotating mass, because the car is so heavy relative to the rims. but also, bigger tires basically means a higher gear ratio, so there'll be a little more resistance to accelleration. but, top speed would be improved a little (itd top out right around 130), and the larger contact patch will improve traction for better launches and better handling at the limits.
basically it might feel a little slower when your just driving around town, but it'll be quicker launching off the line and be able to turn harder without understeering.
jasonbegin
10-27-2005, 02:40 AM
wheelmax. rocks
i cant wait till the spring so i can rock my new 18's
: ) lol
StatuSCheckA
10-27-2005, 05:07 AM
^^Ya, I love Wheel Max.
I think I will order some 18's in a week or so.
Im just kinda nervous about the 1/4 mile time, I dont plan on racing like every week. but witht he CIA, and Exhaust, and misc Bolt Ons, you bet ima race a few times...
But what ALOT of people been saying, it depends on the weight of the rim.
Are the STOCK rims alone really only 20 LBS?!?
trdsparks
10-27-2005, 12:35 PM
Your stock 17's weight 19.5 lbs. According to the shipping scale we use here at the dealership. It weighs in 1/2 pound increments so it may vary a few ounces.
The 18's are only 1 pound more. BUT not all 18 in wheels are that lite. Most of them are 22+ lbs.
I found something interesting out though the Pirelli P-Zero Nero's they use for the 18's at the dealer are actually 1 pound lighter that the 17 in Potenzas. 22lbs vs 23lbs so even if you went with the factory 18's you would keep the same over all weight. Nice to know!
StatuSCheckA
10-27-2005, 01:12 PM
Im really surprised the Toyota 18s are that light, They look so heavy to me? lol
Anyway, thanks yall, I guess I will go as light as I can, and hope my over all 1/4 mile time isn't drastically affected!!
The stock 17's really look good, but since I don't plan on doing to many exterior mods; rims are my only other choice, except for my already installed TRD Exhaust, and possible (but unlikely) Aftermarket Grille upgrade.
Coleman
10-28-2005, 12:18 AM
I have 18 in Konig Unknowns on my 06 TC and for one thing they handle a HELL of a lot better than the stock 17's. I definitely notice a difference in the corner handling and everything. In regards to the difference in the speedometer i was actually informed by the dealership when i bought my 06 in Sept. that the TC has a chip built into it to adjust the speedometer etc for the change in rim size. Dont know is this is all too late but thought i would put my 2 cents in.
StatuSCheckA
10-28-2005, 02:13 AM
NA, thanks alot Bro, that was one of the top 5 posts in this thread.
I love when I start a successful Thread :D
StatuSCheckA
10-28-2005, 08:21 PM
SWEET! I just found out that the 18's that I want are only 22 LBS each, that is just the weight of the rims...so that makes me feel better, that it doesn't affect the performance/Speed of my car (that bad).
Thanks Again Yall.
PS, I wonder if this thread should be copied in a FAQ section??
Revilo
10-28-2005, 08:59 PM
Hey guys... i found a 18" wheels for the Scion tC that weight only 16 lbs... check them out...
http://www.tirerack.com/servlet/CallJsp?target=wheelSearchCloseUp&wheelIndex=46&sizeIndex=0&showRear=no&setIndex=9&filterSize=&filterFinish=&filterSpecial=
They are the Kosei K-1 TS for the Scion tC
http://i23.photobucket.com/albums/b379/OSegura/kosei_k1_ts_ci3_l.jpg
Size Selected: 18x7.5
Price: $275 each
Estimated Availability: In Stock
Recommended Tire Size: 225/40-18
Wheel Offset: +42mm
** Lightweight: 16.0 lbs. **
Additional Specs
Bolt Pattern: 5-100
Finish Warranty: 1 Year
Country of Origin: Japan
Construction Type: G.Cast/SF/Shot Peene
Dr_Isotope
10-28-2005, 09:14 PM
You will definitely feel the difference going from an 18.5lb 17" wheel to a 22lb 18" wheel. All performance aspects will suffer (acceleration, braking, cornering). I hope they're very good looking wheels, because you're making big sacrifices by choosing them. Just FYI.
StatuSCheckA
10-29-2005, 08:37 AM
I knew someone was gonna ruin the mood.
Nick06tC
10-31-2005, 01:03 AM
Since you probably wont be racing through town everyday I think you will be able to deal with this s called big saccrifice. Enjoy them. I just ordered 18 inch Enkei DM5, dont know the weigt but I am not to worried.
mxyzptlk
10-31-2005, 01:31 AM
ACCORDING to my calculations if you had gotten the 18 in wheels when you first got the car you would have saved yourself a lot of money heh heh
StatuSCheckA
10-31-2005, 01:32 AM
oh, good for you. I do drive the car everyday, but do/will not race it offen, i like having the car just for "props" alone, and its fun to drive :D
Hey, are there many tCs around Hampton/Newport News?
I will be in Newport News for a few weeks around Christmas. Usually when I go there, there are quite a few imports and stuff around.
StatuSCheckA
10-31-2005, 01:35 AM
Not a true statement, unless you are talking about the Toyota Upgrades.
:no: And either way, you STILL have to pay the $1500...
If you go aftermarket, it doesn't matter if you get something now or a year from now...
Maybe i'm just not seeing your view point.... :lalala:
Nick06tC
10-31-2005, 10:09 AM
yeah there are a bunch of them around. I have yet to see one modded but there is a guy on this bored that lives in VA beach with the ZPI turbo.
Keep in touch and look me up in december.
Nick06tC
10-31-2005, 10:10 AM
Deffinetly not cheaper from Toyota. They wanted 1650 for the 18's and everykid whose mommy and daddy is paying the car payment will get them just because. I went aftermarket because not as many people are likely to have them and be able to spend the money over the car.
tCb00b
11-02-2005, 03:47 AM
I know Rota makes some nice light wheels but they are mainly smaller diameter so that might not help you. But for those of you who are looking for light weight, inexpensive wheels, give rota a google and find out. I know they are pretty popular with the Honda guys. Just my .02
boostedscion
11-02-2005, 11:35 AM
thanks for the info 18inch do a lot of damage
atodak
08-20-2006, 06:39 PM
