MAF sensor
Old Apr 5, 2004 | 05:38 PM
Emitto666's Avatar
Default MAF sensor
Can somebody tell me how to check if my MAF sensor is clean, and if not how to clean it? My iddle is going up and down, i just installed a Typhoon CAI.
Thx.
Old Apr 5, 2004 | 05:44 PM
Tamago's Avatar
MAF is the little black square sensor that bolts onto the intake tube.
take it out, inspect the diodes etc for dirt or grime.. clean with rubbing alcohol and a q-tip, and let dry..
Old Apr 5, 2004 | 05:47 PM
DibujoB's Avatar
Default Re: MAF sensor
Thx.
Mine did the same thing when I first changed out intakes, but it stopped doing it after a few weeks. I don't think it has to do with the MAF being dirty.
Old Apr 5, 2004 | 06:15 PM
Emitto666's Avatar
Thx for the tip, i appreciated.
Old Apr 5, 2004 | 06:53 PM
Tamago's Avatar
It may not be.. but remember, when the MAF does eventually get dirty, the engine will run like that.
did you reset your ECU by disconnecting your battery?
Old Apr 5, 2004 | 07:00 PM
Emitto666's Avatar
Yeah, i did, when i installed the CAI i did it w/the battery diconnected.
Old Apr 7, 2004 | 05:52 AM
Chrno's Avatar
reset your ecu.. unplug ground wire from battery for 5 mins plug it back in and start engine.. good luck :D
Old Apr 7, 2004 | 05:59 AM
mikochu's Avatar
I unplugged mine for like 3 seconds and my ECU reset. I didn't notice that I reset the ECU. When I saw my trip meters at 0.8 miles (I monitor my mileage), I almost ____ my pants..then I remembered the plug came off when I was wiring my ground wires...
Old Apr 7, 2004 | 02:56 PM
justchico's Avatar
Talking about sensors. Does anyone know were the IAT senor is and what wires are the correct wires to it?
Old Apr 13, 2004 | 08:36 AM
dval43's Avatar
The IAT sensor is the yellow and black wire off of the MAF plug.
Hope this helps... =)
Old Sep 26, 2004 | 02:33 PM
SXT_HuntToKill's Avatar
DelMarVa
you can also reset it by takeing both + side and - side on the battery wires and short them out IF the ECU doesn't reset after 5 sec. doing so this shorts the power still held in the ECU that way it forgets everthing.... 1 thing though this will reset your maintainnece light on the car too so your car will reset everyhting all over again... i had to do this when i was a dumbass and unpluged the MAF plug when the xB was still runnin all my lights inside on the dummy gauges were on... air bag seatbelts TCS teh slippery road car symbol... so your choice use at own risk... nothing bad will happen it will just reset the maintainance as well...
MeDizzy
Oct 8, 2015 03:31 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Gigs
Sep 15, 2015 03:54 AM
Topfueltom69
Sep 6, 2015 05:25 PM
