Where's a good 12v source under the hood??
Old Oct 27, 2005 | 10:14 PM
Prototype_xB's Avatar
Default Where's a good 12v source under the hood??
I'm wiring up some strobes in the headlights for show. I need to find an always on 12v source under the hood to splice into. Where's a good one at, or how can i find one??
Old Oct 27, 2005 | 10:39 PM
jmiller20874's Avatar
Uh, try the battery. Just have the positive wire fused and switched. Simple.
Old Oct 27, 2005 | 11:11 PM
/\/\ the transformer is internally fused. I tried wiring to the battery already but it was just too hard to hide the wiring.
Anyways, i used my trusty test light and found a source!! I had previously thought that the headlight wires weren't hot unless the switch was on. The test light told me otherwise. I spliced into a wire there, and ran everything else:
SUCCESS!!!
Mechanicly inclined i am, electrical i am not, haha.
Old Oct 27, 2005 | 11:12 PM
oh yeah, i wired in a hidden switch under the hood as well.
Old Oct 27, 2005 | 11:23 PM
You could also have just connected it the the wire feeding the fuse block. Good chance you might not have needed to splice anything.
Old Oct 28, 2005 | 12:56 AM
SmartAss's Avatar
Not good to splice into wires and draw current off of them like the headlight wires. This could cuase further problems becuase hte wire is a specific guage for powering the headlights and if your drawing current off of it you could mes the headlights up. I would recoment running 1 8 guage of fthe batter to a distrobution block that you can cleanly mount somewhere in the engine bay and also have a few extra spots to add things later.
Old Oct 28, 2005 | 04:57 AM
Sciond's Avatar
yep avoid the melt down
Old Oct 28, 2005 | 01:50 PM
even though the wiring for the strobes are significanty smaller than the headlight wire i spliced into? Also, the headlights + strobes will never be running at the same time. The strobe circuit is a normally off circuit.
Old Oct 28, 2005 | 01:52 PM
I'll be adding undercar LED's this afternoon, would you agree that it would be better to splice into the LED's power lead rather than the headlight?
Old Oct 28, 2005 | 02:23 PM
markritch's Avatar
for those i would go right to the battery....or go through the firewall into your dash and use the "add a circuit " method into one of the existing fuses
Old Oct 28, 2005 | 10:38 PM
wired the leds to the battery
Old Oct 28, 2005 | 11:42 PM
Tdowg26's Avatar
Fire! Fire! Fire! Huh HUUh!
Old Oct 29, 2005 | 12:08 AM
SmartAss's Avatar
LOL Please please please...... Use is a dsitro block thats fused.
Inazuma
20
May 3, 2023 01:58 AM
scsteven
Jan 25, 2015 01:06 AM
mdhyre
Dec 7, 2014 12:52 AM
scionboxrox
Nov 24, 2014 06:38 PM
IceBox
9
Nov 4, 2003 04:35 AM
