View Full Version : Flush/Not flush..I dont care..Will it rub suspension??
jorez
10-30-2005, 12:47 PM
I just picked up a set of 18x7.5 with a +42 offset. If I put these on an xa that is lowered with DF210 now (going to coilover soon)..
1. will it hit the suspension and keep me from driving??
2. WHat if I just keep the springs and no coilovers??
3.what if I go back to stock springs
If you suggest spacers to miss the suspension, what size..only rear? or front/rear??
THanks
Squishy
10-30-2005, 02:21 PM
I'm getting a +45 offset and ordered onetongarage shims for the rear in case of this issue. I figured better safe than sorry and waiting that extra week or so to install new rims.
jorez
10-30-2005, 02:36 PM
What size spacers did you get for the +45's?
Squishy
10-30-2005, 02:56 PM
Actually I believe Van sent me 10mm rear hub spacer shims.
They make 5mm and 10mm. You can go to www.onetongarage.com and check them out. Mine go behind the brake drum, so you don't need longer lug attachments for the rims.
You can see them here...
http://www.onetongarage.com/products/rear_spacer_shim/index.html
jorez
10-30-2005, 03:44 PM
Yeah. I have seen those. I am wanting to know if I will actually need them. Because I will be using stock rims winter, 17's for summer and 18's for shows. Can I do all this without spacers???? Can I do all that with spacers??? The 17's have +40 and the 15's are stockers.
Anyone else help out??
Squishy
10-31-2005, 03:42 AM
You can do all with spacers.....I only got them for the rear because sometimes the rear has issues with the +45 offset. They will be fine with stock rims as well. It's worth the $65 including shipping IMO
