rear spacer question for rims 17x7 +34mm offset
Old Apr 6, 2004 | 05:36 AM
Gil's Avatar
Gil
Default rear spacer question for rims 17x7 +34mm offset
Another spacer question, I just put my old rims on racing hart type c 17x7 +34mm offset 215/40/17 tires. The front looks good but the rear is not flushed with the fender. How thick of a spacer should I use 5mm? 10mm?? and where can I get a pair of spacers and studs because the stock studs are too short. Also, I am not going to lower the car.
Old Apr 6, 2004 | 06:08 AM
bBOXD's Avatar
Go with a 10mm spacer and some longer studs. I would sugggest lowering the car about 2.25 inches.
Old Apr 6, 2004 | 09:32 PM
Gil's Avatar
Gil
Thanks for your reply, what brand of spacers would you recommend and where can I get a pair? besides H&R backordered?
Old Apr 6, 2004 | 09:49 PM
tbblizzard's Avatar
you got an xa?
Old Apr 6, 2004 | 09:51 PM
Gil's Avatar
Gil
i have an xb.
Old Apr 7, 2004 | 06:13 AM
Opr8r's Avatar
sIcKsCiOnS
For a 17x7 wheel setup, the rear needs an offset of around +15mm to be in the "flush" ballpark.
Peace,
m@
Old Apr 7, 2004 | 04:40 PM
Docofmind's Avatar
If you need spacers hit me up. I got the studs and 10, 15 and 25mm available
Also, i use heat treated anf forged studs unlike H & R
Old Apr 7, 2004 | 05:18 PM
scionmilktruck's Avatar
Can I piggy-back off your post? I just ordered some rims that are 17x7 with a offset of 38mm. What's the spacing I will need for the rear? Also, is it going to look wierd if I don't space them? Thanks :?
Old Apr 7, 2004 | 05:52 PM
bBted's Avatar
get 15mm
Old Apr 12, 2004 | 01:24 PM
KevinA's Avatar
I just want to clarify something. To ensure a "flush" look, one would need a +50 offset on a 17" x 7" wheel (xB)? That just sounds too aggresive.
Old Apr 12, 2004 | 01:51 PM
superjeer's Avatar
no, other way.. you'd want a 15mm offset (with 7 inch wheels). So, I'm running 25mm ET on a 7" wheel. To push the backs out more to look more like the fronts I'd want a 10mm spacer and some studs so the nuts will still be able to hold the wheels on.
the more the offset the more sunk-in the wheel is. The less the offest the more the wheels stick out.
Old Apr 12, 2004 | 05:47 PM
KevinA's Avatar
Thanks, I'm new at this offset stuff.
Old Apr 12, 2004 | 05:54 PM
I put my wheels on Saturday and I must say that I might leave them as is. They are 17 x 7 w/ a offset of 38mm. So put your wheels on and see how you like them. I was driving myself crazy wondering if I should get spacers before the wheels even came.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
terrye
Jul 11, 2015 11:54 PM
scionlife
371
Jun 2, 2015 11:00 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
