Cigarette Lighter/ LED question
Old Nov 4, 2005 | 05:01 PM
HeathenBrewing's Avatar
Default Cigarette Lighter/ LED question
Has any one tapped into the cig. lighter to run a single FLASHING LED?
I want to install a flashing alarm LED (in other words a fake alarm) in the dash and was wondering if I should run a line from the battery to the LED, or if I can just tap off the lighter. I do not use the lighter for smoking or to power any other devices, so it will never be used unless I splice into it.
Heres what Im thinking:
Battery > inline fuse > rocker switch > LED
Any links to some kind of wiring diagram for the lighter?
Any advice?
Thanks
Old Nov 4, 2005 | 05:16 PM
TheScionicMan's Avatar
You can do it. there's just two wires, one hot, one ground. Another nice option is this thing called an Add-A-Tap. You'll want the Mini Add-A-Tap for the smaller size fuses we have. At least the Box, I'm guessing the tC is the same. You can usually find them at auto parts stores. Here's an example:
http://www.midterminc.com/en-us/dept_91.html
No cutting of the OEM wiring and it's fused for safety. Just connect the hot of the device to the wire and ground the negative.
There's a post around somewhere about which open fuse spots were hot. A 12V test light should tell you also.
Old Nov 4, 2005 | 05:25 PM
sfusco's Avatar
the cigerette lighter only has power then the key is in the on postion
Old Nov 4, 2005 | 05:37 PM
Ahh haa...I was thinking that might be the case.
Anyone else?
Old Nov 4, 2005 | 05:39 PM
Sweet. I might not go that route now.
By chance do you know if I can buy an adaptor that would fit into the stock wire harness under the center console for mounting some LED's? I am looking to NOT cut any of my stock wires.
Old Nov 4, 2005 | 06:06 PM
Some good info here:
https://www.scionlife.com/forums/viewtopic.php?t=29238
Old Nov 4, 2005 | 07:11 PM
Cheers!
Old Nov 5, 2005 | 05:09 AM
SCXB's Avatar
I believe the radio power wire could be tapped into, even with the key off the radio still gets a little power for the presets.
Old Nov 5, 2005 | 06:07 AM
Mmartin_47's Avatar
tap into the the constant wire in which the stereo gets power to hold memory.. i forgot the color.. its either red or gray?
Old Nov 5, 2005 | 10:40 AM
brownbanana's Avatar
yea, youd have to tap the wire that gives constant power to it.
Old Nov 5, 2005 | 01:07 PM
Bgnome's Avatar
mine is one of those chaser leds. i have it getting constant power from the fog light relay. it is switched on automatically when the cig lighter grounds, which is when the car is turned off.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
