i know this sounds strange but my wife builds up a serious static charge whenever she rides shotgun in the xb. then when she gets out she ends up shocking herself with an impresive amount of voltage differential. It never happens to me or any other front seat passengers just her. Does this happen to anyone else? Any suggestions or solutions?
doctorcue
10-21-2003, 09:48 PM
Don't let her ride in it! That opens up another seat for the honeys!
BlueBox
10-21-2003, 10:02 PM
well...i guess some ppl are more prone to static charges... in japan it's a common thing... and anti-static key chain mechanism sell readily...u can get these at small japanese auto parts store or at SUPERAUTOBACS at Stanton, Ca. Price ranges from $10 up to $30 depending on wat features it has...some has built-in lights and other stuff.
here's an example of such product... and from wat i heard...the mechanism neutralizes the positive ions or something in ur body so that u don't shock urself when u touch the car.
weird! but sweet thanks blubox! that gives me an excuse to go next time im down there.
xB_ey
10-22-2003, 12:17 AM
doctorcue: ...i don't think you helped LVXB at all...but it sure did make me crack up for a few minutes!!! :lol:
its_ikon
10-22-2003, 12:34 AM
i just thought i was wierd, but i build up a static charge and when i go to get out of my car i always get shocked.
showpaojoe
10-22-2003, 12:54 AM
Just don't let your wife fill up the gas tank, she'll make her own flamethrower.
MadSciontist
10-22-2003, 02:38 AM
I was watching myth busters and they had the gas station fire from static and cell phones. For the static they used a car seat and a pair of panties, so tell your wife when she wants to ride then take off the draws :wink:
LVXB
10-22-2003, 03:07 AM
nyyyyyce!
George
10-22-2003, 05:07 AM
This is a common problem these days, when none of the surfaces in the vehicle are grounded. Since the passengers are completely insulated, they can build up a considerable static charge which gives them a "zap" when they do finally get near a ground.
The only (possibly) grounded items that you can touch in the front seat are the button on the parking brake, the ring around the cigarette lighter, and the ignition key. Down lower, you have the seat rails and seat adjusters. Since the driver touches the brake and key before getting out of the car, the driver doesn't get shocked. The passenger can do the same and avoid the zap.
Women seem to be more susceptable to getting zapped, probably because of the fabrics they wear and/or the insulating qualities of their shoes. I doubt that your wife would appreciate a suggestion of wearing different clothes in the xB, though!
Fires while fueling are a remote possibility, but in California with vapor recovery nozzles the chances are slim. It _has_ happened, though, usually when the person fueling has left the nozzle on "auto", entered the vehicle for some reason, and returned to remove the nozzle. As soon as they touch the nozzle, a spark jumps and if there is a combustible mixture it lights! Ow!
George
scionspecialistvegas
10-22-2003, 10:55 AM
Dude, I thought my wife was the only one that sufferred from this ailment. The no ground is probably right. My wife hates it but she still won't drive unless I force her.
I used to tease her about it being a pinay thing. Anyways thanks everyone for the grounding tip.
eric_m
10-22-2003, 04:19 PM
george, would touching the door frame before you exit the vehicle be a good enough ground to discharge you, or does it need to be an unpainted surface?
George
10-22-2003, 04:33 PM
That is a good question. It depends upon the insulation value of the paint or other coating. I think that the most direct fix would be to run a fine wire from the screw behind the inside door handle and glue it to the back of the handle, so you touch it when you open the door. That would be out of sight and would serve to discharge the passenger without any effort on their part.
Of course, I see static buildup as an interesting phenomenon. Why ruin the fun? :)
George
LVXB
10-23-2003, 10:46 PM
helpful as usual gentleman! i shall dutifully report to the mrs.
Inazuma
11-26-2003, 03:04 PM
Just FYI....
It used to happen to me in the past no matter what car i was in...
I narrowed it down to only 1 thing.....
Its the type of shoes you are wearing...
A good pair of quality shoes with REAL rubber soles will eliminate the problem.
I noticed the shoes i was wearing at the time were the synthetic rubber soles...
I bought a pair of DR. Martins and the problem was GONE!!!
I am not saying to by DR. Martins shoes...it was just an example of a real rubber sole..
kikimaja
11-26-2003, 04:09 PM
I was watching a show a few months ago and it had a segement about this very thing.
Both drivers and passengers can build up a certain amount of static charge while in the car. The show suggested that when getting out to touch the metal part of the car with your hand flat on it. This will disengage any static in the body.
Also, when you do go to the gas station they say to not use your cell phone or get in and out of your car while the gas is pumping. This also builds up the amount of static. Slim chance or not, there have been reports where people catch themselves on fire at gas stations due to this. So, just touch the metal area of the car flat handed when you get out.
tat2dude25
02-13-2006, 03:24 AM
Static is real as far as the cars go. Tonight was getting out of my Box and touched the exterior painted surface of my car above the driver window and could literally see the static. Yeah got a shock, Big deal. As far as fueling a car, PLEASE DO NOT ENTER YOUR CAR WHILE FUELING. Sorry for the caps! It is dangerous! Its true, especially for women and certain pantyhose and garments they wear. I am a manager at a gas station where a lady did just that and got out of her car to put the nozzle back on the pump and discharged her static into the fumes from it and her tank. Nice little fireball! Fortunately no damage or injury just a scare with fumes burning off. This is all on tape in our company files. Also, those nice little auto shutoffs on the pump dont always work. HINT HINT. I have almost had to call the EPA when someone is in their car with the auto shutoff on and gasoline spraying out of their overly full tank.
doctorcue
02-13-2006, 05:22 AM
It's a zombie! Cuz this is from the dead!!!!
Spr0ket
02-13-2006, 06:03 AM
Holy Carp! 2003!?
TheIcon
02-13-2006, 01:10 PM
Yea I get the shytttttt shocked out of me. I see frikin lightening coming from my fingers like Zeus
LVXB
02-13-2006, 03:34 PM
bump from the grave indeed!
anyways if anyone cares the ultimate reason for the statc was the stock tires once we switched to performance tires the static ceased.
one question though my post count used to be well over two thousand and most of those posts were well after this one. So what happened to all of those?
TheIcon
02-13-2006, 04:20 PM
Post whore. jk jk :) Wish my Zeus like characteristics ceased when I got rid of my stock tires.
ProshopXB
02-14-2006, 12:57 AM
Lvxb its funny im having the opposite effect from the tires, never had static electricity until i changed the stocks out to performance tires, LoL. But i felt like zues also, has more bass from the electric charge when i would touch the door, then i did from my sub, LoL. aahhh darn static electricity
ApostolicFire
02-14-2006, 04:30 AM
I have this problem seriously, too. When I step out of my car, I get my house key (seems to work the best) and touch a metal part of the vehicle with the key. Usually do it in the sill of the door. I'm sure the question will get asked, but no, I haven't made any scratches from doing this because I just barely touch it.
I know there are cordless anti-static wriststraps for computer servicing, but I haven't tried that to see if it works. Here is an example of what I'm talking about if someone wants to give it a try:
http://www.cyberguys.com/templates/searchdetail.asp?T1=116+0125
