How do i remove the radio in my xb
Old Nov 6, 2005 | 01:40 PM
notscubasteve's Avatar
Default How do i remove the radio in my xb
i have sirius but i hate the seprate unit. i want to intergrate it to my radio. how do i get to the back of the stereo to pug in the module
Old Nov 6, 2005 | 02:40 PM
xBHAWK's Avatar
Default ...somewhat easy....
I just removed the radio head unit in my XB.
Pull off the three climate control *****.
Unscrew the 2 philip head screws beneith the *****.
Now, wiggle the silver out by moving it side to side near the bottom.
The top of this silver sub-dash is hinged at the top, so pull it out by the bottom first.
Once this is removed, 4 screws hold the radio head unit in. Unclip the connections in the back of the unit.
There are several write-ups on removing this sub-dash but only doing it will allow you to understand fully.
Old Nov 6, 2005 | 04:19 PM
Romanova's Avatar
Look at the Camry nav install in the tech section...
Old Nov 7, 2005 | 05:47 AM
xBHAWK's Avatar
Default ...Your so MYOPIC.....
Well, to be correct, your instructions were correct and my instructions ignored one key element that could really cause a problem. Those 3 wiring harnesses that go into those 3 connectors need to be removed by depressing the tab and removing the connection socket. There is only about 4 inches of extra play in the wires, so you have to do this without seeing it behind the silver dash part.
How could I forget that?
Don't be sorry... be MYOPIC.... The more correct instructions should allways be the goal here in Scion Life.
Old Nov 7, 2005 | 11:39 AM
larry_flint's Avatar
Default Re: ...Your so MYOPIC.....
Originally Posted by xBHAWK
my instructions ignored one key element that could really cause a problem. Those 3 wiring harnesses that go into those 3 connectors need to be removed .
im sure he wouldnt just start YANKING it out and destroying the harness.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
Nargrakhan
Scion iQ ICE & Interior
Dec 10, 2014 06:10 AM
