Optimal Shiftpoints for the Track?
Old Nov 7, 2005 | 12:46 AM
kanundrum's Avatar
Default Optimal Shiftpoints for the Track?
Hey all just wanted to know the optimal shiftpoints for the dragstrip. Ive been about 3
times now and the best i seem to get is about a 16.1.
i want to get a 15.7 so i wanted to know when should i shift, at wat RPM is the best time
to shift for best quarter mile.
Thanks
BTW I searched, didnt really find much.
Old Nov 7, 2005 | 01:38 AM
fac3's Avatar
It's not really about shift points.
It's about how you launch, how much you weigh in the car, the weather, etc etc
Old Nov 7, 2005 | 01:48 AM
toyota_scion_tc's Avatar
That's not true! The launch, shift points, and your own weight does make a diffrence. What are your 60ft times?
Old Nov 7, 2005 | 03:08 AM
06tCguy's Avatar
if you're stock, 15.7 is good..what the magazines got. when you feel torque starting to drop off, shift..you don't need to run it to redline each shift..
Old Nov 7, 2005 | 03:43 AM
kanundrum's Avatar
hmm kewl. i will post up my 60 times in a few. wat are good launching techniques then
Old Nov 7, 2005 | 03:54 AM
06tCguy's Avatar
slip the clutch a bit so there isn't as much wheel hop/spin. people say around 2300..
Old Nov 7, 2005 | 04:33 AM
kanundrum's Avatar
so basically rev it until about 2300 with the clutch out a little and then punch it when the light turns to the second yellow ( for good r/t)
Old Nov 7, 2005 | 11:48 AM
06tCguy's Avatar
hold it at 2300 then slowly let the clutch out, then get on it. and yeah, second yellow.
Old Nov 7, 2005 | 03:35 PM
kanundrum's Avatar
ok so my 0-60 time is 2.340 while my r/t is .944 1/8 = 10.415 and 1/4 was 16.143 @ 87.95 mph
Old Nov 7, 2005 | 03:36 PM
Voltairecim's Avatar
If your car's stock, isn't 5700 peak horsepower?
Old Nov 7, 2005 | 04:04 PM
rlazer5000's Avatar
If you can get your 60' times under 2 seconds you should run a really nice 1/4 mile time. Your launch is pretty important so just figure out what technique works the best for you. I'm used to driving an AWD car, so I'm not sure how it works with a FWD car. Good luck man!
Old Nov 7, 2005 | 09:14 PM
Your 60' isn't that bad with the same 60' I ran a 15.5 stock. Were are you shifting at. It just as bad to shift too early than too late. You will have to find the happy medium. Try shifting around 5800 and see what your 1/4 turns out to be. I am trying to get to the track this week to see where I am now. I know I will break 14's now. I let you know what I get and where I shifted at.
Old Nov 7, 2005 | 09:18 PM
aarontrini85's Avatar
actualy on the tc redline is a good shift point before my exhaust i hit 15.2's shifting there now i have my exhasut and im going to try and cut some weight out of this fat B!tCh and take it to the track one more time before the season is up witch is like 2 more weeks i think
Old Nov 7, 2005 | 09:43 PM
fac3's Avatar
Um.
Thats what I meant.
Old Nov 7, 2005 | 10:10 PM
heyitznosaj's Avatar
i usually shift at 6k. When i try to get over that usually bump the rev limiter but I only redlined in 1st gear. The most i ever gotten to redline in 2nd is to around 5500 and you can start feeling a drop in torque. 6k rpm to shift at.
05rs1
Dec 9, 2016 02:18 PM
Luna7ic
Sep 28, 2015 03:30 PM
ScionLife Editor
Sep 8, 2015 07:10 PM
Subaru86
Jul 31, 2015 04:00 AM
carid
Feb 12, 2015 11:54 AM
