Alignment, how long should you wait after you lower your car
Old Nov 8, 2005 | 05:28 PM
tranceisgood4u's Avatar
Default Alignment, how long should you wait after you lower your car
I'm planning on getting my TRD springs, TRD Rear Sway Bar and DC Tower Strut Bar installed this Friday. When should I go get F&R alignment? Should I give the springs some time to settle or get it done immediately? Thanks.
Old Nov 8, 2005 | 05:59 PM
The_Instigator's Avatar
Ideally you should get it done as soon as possible...especially if youve spent good money on better tires. If youre on stockers and are looking for a reason to upgrade you tires like me , then not getting the car aligned will help to wear them out quicker if the toe has changed. My car still tracks perfectly straight and handles nicely, but Im not sure whether or not the toe is out of whack.
Old Nov 8, 2005 | 10:26 PM
ScionEyes's Avatar
KAD
would you then say every oil change??? 3-5k
Old Nov 9, 2005 | 04:01 PM
-NEMESIS-'s Avatar
i drove mine for a few miles just to check things out...... then got my alignment done.
Old Nov 11, 2005 | 08:57 PM
intakeonly's Avatar
yeah, definitely get alignment done asap because it totally makes a difference in under/over steer after it is balanced out
for me i waited, over 4 months until i got alignment done.
mileage per gallon went up!
Old Nov 11, 2005 | 11:33 PM
ScionEyes's Avatar
KAD
ok talked to the pro's
when you have your vehicle dropped you must do it every 3k-5k miles!
hope it helps!
Old Nov 11, 2005 | 11:47 PM
DuMa's Avatar
if it really helps mpg then haha i havent done it since i dropped my car. no wonder i have been getting ____ty mpg
Old Nov 12, 2005 | 11:43 AM
boostedscion's Avatar
just give it 1-2 weeks to settle then get your alignment done.. did you already get your stuff? R you getting it installed at power cerritos?
Old Nov 13, 2005 | 02:19 AM
bzboardz's Avatar
is there any recomended place to get alignment done? or should i just go over to a tire shop
Old Nov 13, 2005 | 03:30 AM
scionspecialistvegas's Avatar
hope it helps!
Sound s a little excessive to me. In fact, sounds expensive to me. I have 39,000 on my box, and it been dropped since it had 800 miles. Now I have lowered over a dozen TC's and only one needed an alignment, but then he found out after paying $120.00 for his alignment, he still had the front end shake. Turned out front tire was out of balance and the alignment was not needed.
I am not saying that an alignment is not a good thing, but if you notice an under or oversteer, or abnormal tire wear then by all means get it to a shop.
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
CAtC12
Dec 23, 2014 04:44 PM
minter66
Dec 15, 2014 01:45 PM
Besk_one
Oct 16, 2003 07:45 PM
