will this cf engine cover fit the tc? and would you...
Old Nov 9, 2005 | 03:35 AM
Fujiz_xb's Avatar
sIcKsCiOnS
Default will this cf engine cover fit the tc? and would you...
will this cover fit the tc?
would you buy and modify it?
or get another one that doesnt need modifyin?
Please reply I need your replies to make a decision.
the more the replies the better and with constructive feedback is appreciated.
http://www.imagestation.com/picture/...3/f19b8193.jpg
http://www.imagestation.com/picture/...b/f19b7edd.jpg
Old Nov 9, 2005 | 04:34 AM
gwtc's Avatar
What kind of modifications are we talking bout here? it looks like an engine cover of the tC, what's wrong with it?
Old Nov 9, 2005 | 04:38 AM
rolstc's Avatar
cover only takes 2 holes. There are four there. And the two holes on the cover he has serve no purpose. Also the holes that do serve a purpose to to be drilled to make it fit. So yea and the company doesnt want to refund his money.
Old Nov 9, 2005 | 04:39 AM
Fujiz_xb's Avatar
sIcKsCiOnS
the tc has 2 screws in the front only not the rear which in return has two extra holes in the back that are drilled when the ones in the front should be drilled.
Old Nov 9, 2005 | 04:58 AM
gwtc's Avatar
Oh...... its probably a Camry CF engine cover then. If the company does not want to give him his money back, then yes, I would modify it to fit. Who is this company by the way?
Old Nov 9, 2005 | 05:01 AM
Fujiz_xb's Avatar
sIcKsCiOnS
camry you say? either that or the corolla. but deff not the tc .
but would you modify and not mind the extra two holes?
Old Nov 9, 2005 | 05:05 AM
gwtc's Avatar
I wouldn't mind the extra 2 holes, I would just put 2 small stickers over them, like maybe 2 scion logos or something.
Old Nov 9, 2005 | 02:15 PM
latinracer's Avatar
see this is mine sorry it a bad angle but you get the idea
Old Nov 9, 2005 | 02:38 PM
Fujiz_xb's Avatar
sIcKsCiOnS
thanks. I'm trying so hard to explain to the co. that i bought it from that my cover should look like yours and he says that i have to modify it to fit and wont refund me because i choose not to use it.
He is saying that all aftermarket parts need modifying and that customers will buy his cover because they understand the fact that its aftermarket.
Their company motto is that they test fit before they produce it and won't sell if it is defective. The way they are handling this they are misrepresing themselves and giving false advertisement. can you pm where you got yours from?
Old Nov 9, 2005 | 02:58 PM
rolstc's Avatar
umm you wouldnt mind the two holes ?? you're crazy man !
Old Nov 9, 2005 | 03:19 PM
vortexofhate's Avatar
What company did you get it through? I wouldn't modify it. They just sent you the wrong product and should send you out the correct one and I would keep on pursuing getting your money back or a correct one sent to you.
Old Nov 9, 2005 | 03:56 PM
Fujiz_xb's Avatar
sIcKsCiOnS
^^ thank you my toughts are the same.
Old Nov 9, 2005 | 03:57 PM
gwtc's Avatar
What I meant to say is, if the company would not take it back and I was stuck with it, I would make the best of my situation and modify it and found a way to cover the extra 2 holes, of course if the company took it back i woudn't keep it.
Old Nov 9, 2005 | 04:02 PM
gwtc's Avatar
Racing solution sells a pritty nice and cheap one for $110.00:
http://www.racingsolution.com/showpa...on=DisplayPart
Old Nov 9, 2005 | 06:01 PM
Fujiz_xb's Avatar
sIcKsCiOnS
not only that but i has the 2 correct screws drilled and not two extra useless holes that the co. claims its there for looks.
Old Nov 9, 2005 | 06:46 PM
krdshrk's Avatar
I've seen someone with the Camry Engine cover.. It fits fine, as our engine is the camry's. You just have 2 extra holes...
Old Nov 10, 2005 | 01:09 AM
Mista3's Avatar
A question for the OP, when you first put on the CF engine Cover did you remove the oil cap with it on? Its kind of a wierd question I know but I have a CF engine cover too and inorder to put oil into the engine I have to take the engine cover off and then unscrew the oil cap. Its kind of an annoyance but lets face it, how often do you put oil into the engine? You might be able to get the seller for that if it applies to you. Oh, and my CF engine cover only has 2 holes where they are suppose to be.
Old Nov 10, 2005 | 02:02 AM
gwtc's Avatar
You shouldn't have to remove the engine cover to remove the oil cap, I guess the hole is too small, I'm only saying that cause I used to have one and I never had to remove it for oil changes.
Old Nov 10, 2005 | 03:30 AM
Fujiz_xb's Avatar
sIcKsCiOnS
i could not install it. the front two holes where not drilled therefore it could not be used.
Old Nov 10, 2005 | 03:46 AM
Parts_Pimp's Avatar
I would send that back and demand a refund. I am going to start making and selling our Turbo Kit for the TC real soon.So does that mean that I can do less R&D because it is after market and give you a kit that does not fit. No I cant. If they told you it is for that car then it should fit with no mods.
