startup prob
Old Nov 10, 2005 | 05:25 AM
sportmaned's Avatar
Default startup prob
Lately, I'd say 80% of the time i try starting my car, it wont start the first time, it doesnt even roll or anything, I'd turn the key, the radio would go off, and the engine would not budge. I thought about it, and was like oh, maybe if i press the clutch after i turn the electricity on then it might start, iono... maybe? Well taht wasnt the problem. I usually just got to let off the clutch thenn press it again and it'll start up, but what's wrong? is this normal? i can't go to the dealer about this, evertime i try it there it worx. Only once or twice has the car rolled and immediately cut out, not like the sound where it's dead and needs to be jumped, but it would roll for a second and totally shut off.
Old Nov 10, 2005 | 05:28 AM
The_Instigator's Avatar
Just press the clutch pedal all the way to the floor. Theres a switch that needs to be depressed in order for the car to start. I find that sometimes the edge of my foot hits the dead pedal and the car wont start. If I slide my foot over a little bit I can depress the pedal all the way down and it always starts.
Old Nov 10, 2005 | 07:23 PM
tekniq's Avatar
Do you have an aftermarket alarm with remote start/engine immobilizer?
Old Nov 10, 2005 | 07:39 PM
StatuSCheckA's Avatar
Do you have a grounding Kit?? Maybe some starter wire is loose or something??
Old Nov 10, 2005 | 09:01 PM
xnevergiveinx's Avatar
i had the same problem. i added some little rubber bump stoppers on the metal tab on the clutch that pushed on the clutch start switch (i think it's called neutral safety or something) i wasn't pushing down far enough. also, check your floormats, sometimes they can get bunched up or aftermarket ones are thicker and won't let the switch engage to start the car.
Old Nov 10, 2005 | 09:13 PM
krix's Avatar
i just got my o6 tc three weeks ago and yesterday when i tried to start my car it didnt do it the first time but the second time it did....im not too sure if i stepped on the clutch fully but it was weird!
Old Nov 10, 2005 | 09:31 PM
aarontrini85's Avatar
just hook the 2 wires on the clutch switch up together i did it when that pos switch broke and my car starts fine now all the time
Old Nov 10, 2005 | 09:43 PM
sportmaned's Avatar
no grounding wires or remote alarm, but today, i was comming home from school, i press down the pedal, turn the key and it did it again, nothing happened, i kept the key turned, and i put alot of force on the pedal and it started, i guess maybe my switch is way down there, it felt liek i indented the carpet for it to start. but yeah, no big deal either way, just a little curious
Old Nov 11, 2005 | 03:51 AM
krix's Avatar
dam....yo it did it again today! what should i do? should i wait till it happens one more time or should i bring it in....alot of people told me that its no biggy but, my car is 3 weeks old....its not suppose to happen. need some advice!
Old Nov 11, 2005 | 04:03 AM
Just remember to fully compress the clutch. If you dont activate that switch it wont start.
Old Nov 11, 2005 | 04:56 AM
sportmaned's Avatar
^^^ when he says fully, he means FULLY!!!! i experienced this today, most of the time i think it's all the way, but that 5mm of gap counts
Old Nov 11, 2005 | 05:02 AM
sprslug_182's Avatar
There is a DIY on how to fix this little problem, just search for it under the tC forum. Im not exactly sure what it is, but the guy wasnt doing it for this problem, but im truly sure it will help you out quite a bit. That stupid switch is definitely a safety item.
Old Nov 11, 2005 | 10:18 AM
krix's Avatar
thanx ill try it!...let me see what happens!
Old Nov 11, 2005 | 12:43 PM
Sanjuro's Avatar
No doubt guys, that clutch needs to be jammed to the floor. I even did a 'half start' a couple of times before I came to this realization. Pretty embarressing in a parking lot full of people.
steeze69
May 24, 2021 02:57 AM
TinmanTC
Jul 12, 2015 07:53 PM
adorable
Jan 28, 2005 11:07 PM
kyleb350
Nov 20, 2004 06:49 PM
OKIHost
Oct 27, 2004 07:56 PM
