Grounding point for amp mounted under driver's seat?
Old Nov 13, 2005 | 04:42 PM
Romanova's Avatar
Default Grounding point for amp mounted under driver's seat?
Any recommendations for grounding points for a amp mounted under the driver's side seat?
Thanks!
Old Nov 13, 2005 | 06:22 PM
kloquewerk's Avatar
you could pop out the center console and use one of the screws mounted to the chassis under there. pull out the little piece of felt from the rear cupholder and unscrew the screw then carefully pull the console up untill it pops off. might take a little force in the front because there are two plugs holding it down. once you remove the console you will see a few different options there. hope this helps
Old Nov 13, 2005 | 06:55 PM
hotbox05's Avatar
um one of the seats mount bolts........
Old Nov 13, 2005 | 08:28 PM
kloquewerk's Avatar
^that works, too lol.
HotLavaDestiny
Feb 8, 2015 05:25 AM
toyotaisme
Jan 10, 2015 10:24 PM
TheTripleC
Jan 4, 2015 06:46 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
vpkb
12
Oct 8, 2003 04:17 AM
