TC Dry Shot 9 oz Bottle...
Old Nov 25, 2005 | 02:06 AM
surfripcurl's Avatar
DelMarVa
Default TC Dry Shot 9 oz Bottle...
Has anyone seen this product? is it any good? what mods should u have to run with it?
just interested because of how small it is...
what i cant understand is how the motor wont redline if u use this... it needs a 6th sooo bad
http://cgi.ebay.com/ebaymotors/Nitro...spagenameZWDVW
Old Nov 25, 2005 | 02:14 AM
318_tC's Avatar
just no.....
Old Nov 25, 2005 | 02:26 AM
TCMONKEE's Avatar
reminds me of the fast and the furious except the guy used like 3-5 of those bottles...
Old Nov 25, 2005 | 02:35 AM
VVTIGUY's Avatar
I think the name speaks for itself...
SHADY Shot
Old Nov 25, 2005 | 03:05 AM
808flintscion's Avatar
hahha!! Is'nt that a 9oz co2 bottle for paintball? I don't know kid.. i would'nt buy it.
Old Nov 25, 2005 | 05:19 PM
aarontrini85's Avatar
the first reason to say no is its a DRY shot in other words run lean and detonate me please
2nd reson is its a no name company well not no name but i wouldnt buy any thing from them
if you realy want to cheap out and buy a dry nitorous kit rather then wet atleast get a good one
http://www.prostreetonline.com/buy/n...idden_systems/
although i have had issues in the past with prostreet so buy it else where
Old Nov 25, 2005 | 06:18 PM
BeaumontTC's Avatar
it looks like a 9 oz. CO2 tank for paintball and they put a sticker on it and filled it with N2O and it called Shady Shot. Dude don't buy it
Old Nov 25, 2005 | 08:23 PM
ack154's Avatar
Moved to PH.
Old Nov 25, 2005 | 11:21 PM
boostedscion's Avatar
lol...looks like a 9oz paintball CO2tank with a new sticker on it with some fittings thrown in
Old Nov 26, 2005 | 12:22 AM
StatuSCheckA's Avatar
DAMN!!! This dude is making living off this ish!!
Nothing More Than A Paintball Co2 Bottle & Plastic Line! Sent Back, No Refund!
Buyer XXXXX( 682) Oct-28-05 06:54 8005640725
Rating Mutually Withdrawn: Buyer and seller mutually agreed to withdraw feedback for this item. Learn more.
Old Nov 26, 2005 | 01:30 AM
WeDriveScions's Avatar
Another example of EBAY Crap.... If you want N2O... YOU MUST do you research and plan on spending at least 700-800 dollars minimum for the neccesities...
Old Nov 26, 2005 | 02:46 AM
DelMarVa
thanks for all the support guys!!! if i was to do like a 10 lb NX bottle (wet) what mods should be done before so i dont blow it up? like i know ill be spending like 599-700 for the NX kit... but what would happen if i put the kit in with no mods. and used it just as like a spiratic extra little boost here and there? like that the only thing i want... i dont race much at all-- i need help with this! i know nothing about setups etc.
Old Nov 26, 2005 | 03:08 AM
I'm going with the ZEX kit, as it's about the same price, but turns on the N2O at full throttle using the throttle position wire, instead of a microswitch in the engine bay, which I like a whole lot more safety wise...
You really should not go over a 50 shot and you should look at a wet "Fogger" kit, instead of a dry kit, as it'll be a bit safer overall... that is if your worried about your engine... you can run 75, but you'd need to be really careful.
The extras you should run is a bottle guage, to know your pressure, a safety blow down kit, a bottle heater, and a purge kit is always nice... you'll also most probably run premium fuel.... and have to run at least 1 step colder plugs to prevent problems...
It gets more detailed than plug and play.... but, this info will get you started on your journey...
Old Nov 26, 2005 | 03:25 AM
DelMarVa
do u have the exact link of the kit for the scion (ZEX) cause thats the kind of induction i want.. full throttle..
Old Nov 26, 2005 | 03:37 AM
WWW.ZEX.COM
For Info and Install Instructions...
Here is a simple link from google for prices... you local speed shop should be able to get one too...
You want the ZEX 82021 Univeral....
Click Here for More Info about the 82021
Old Nov 26, 2005 | 03:39 AM
DelMarVa
would this be the kit i need?
http://www.powerandperformancenews.c...NITROUSSYSTEMS
Old Nov 26, 2005 | 03:41 AM
DelMarVa
ooooooooo awesome man thanks
DelMarVa
how hard are these things to install?
Old Nov 26, 2005 | 03:46 AM
No problem on the info... it's what I do...
In regards to install, there is the guide on the zex website... it's a little time consuming, but pretty straightforward.... lots of running hose and wires....hardest part is probably running the wires from the selonoid box to the cabin through the firewall.... Just make sure to follow ALL the instructions and best to have someone knowledgable in N2O helping you out...
Old Nov 26, 2005 | 04:00 AM
DelMarVa
when are u doing yours? ultimatly the car will redline alot faster correct? what are you going to do to change this?
