View Full Version : Can't get AM stations at all?
crystaljukebox_com
10-23-2003, 09:04 PM
Since I had my Panasonic tv/dvd 7200 installed, I get no AM stations at all.
Did they NOT hook up the antenna?
Is there an antenna on the xb?
What can I get to help boost the AM signal?
http://www.crystaljukebox.com/scion/panasonictv.jpg
eric_m
10-23-2003, 09:12 PM
there are 2 antennas in the xB. each is mounted on the rear side windows. it is possible that one of them came unplugged because they need a power source in order to amplify the signal. if FM is working, then try checking the connections on the wires coming from the in glass antennas, which are behind the plastic covers in the rear. i don't know which one is AM and which is FM, but that's probably the best bet. have the stereo shop check it out.
crystaljukebox_com
10-23-2003, 09:21 PM
Look at this pic, is there an easy way to get back there????
Into the side panels, without moving this box too much?
http://www.crystaljukebox.com/scion/box.jpg
eric_m
10-23-2003, 09:51 PM
nice box. yeah, i should have been more clear. i meant the upper, light colored side panels. you can start at the corner where the hatch is and pry the plastic back. there should be a small plastic connector right near the back of the rear glass, and somehow maybe one of them got disconnected. it's just a guess though. i'm not sure.
MaxPower
10-23-2003, 10:06 PM
What did you do with your stock radio? Want to sell it? :)
coasterlvr
10-23-2003, 10:11 PM
They probably did not hook up the power antenna wire. The antennas are amplified and need power to work right. FM will come in ok but AM will be bad.
JT
DibujoB
10-23-2003, 10:23 PM
nice box.
Hee hee. :lol:
ok, i'm juvenile.
eric_m
10-23-2003, 10:38 PM
nice box.
Hee hee. :lol:
ok, i'm juvenile.
you're just jealous because you don't have 4 x 10".
DibujoB
10-23-2003, 11:42 PM
You're right about that. I definately need to get a system in the not too distant future. Heck, I'm still saving up for wheels.
he does have a nice box though!
showpaojoe
10-24-2003, 12:30 AM
I actually don't get fm that good. I'm running a monitor/dvd/tv tuner and the fm sux. I still get it but its static and if I go places were the original radio was deccent enough, I don't get anything, just spanish channels. The guy at the stereo shop said it uses the tv antenna, is that correct? That sux if it's like the tv and only gets good reception when the car is still.
shaefner
10-26-2003, 04:21 AM
Besides hooking up the coaxial antenna wire to your deck, you also have to hook up the power antenna wire (usually blue) on your deck to the factory wiring (blue wire on the Toyota wiring harness I bought).
Scott
crystaljukebox_com
11-10-2003, 08:26 PM
My FM is pretty bad also...but when I had the same unit in my Avalanche, it worked pretty good. Got FM with NO static and got AM damn good.
Probably gotta take back to shop. I wanna sell this unit and get the 7300 so I can get Sirius Sat. radio.
OH WELL, always something!
George
11-10-2003, 09:12 PM
You have this setup and you want to listen to AM radio??!!! :)
