removing stock headers?
Old Nov 28, 2005 | 04:06 AM
TruTriNiPlaYa's Avatar
Default removing stock headers?
In the process of installing alphawerks headers....we ran into a problem removing the bottom left nut...no room for play any suggestions??
Old Nov 28, 2005 | 12:40 PM
dgHotLava's Avatar
better tools...
and moved.
Old Nov 28, 2005 | 01:15 PM
Simplyscion's Avatar
Team No Limitz
an offset 12 mm wrench will do the trick
Old Nov 28, 2005 | 01:50 PM
bluenjsciontc's Avatar
doesnt sound like you have all the right tools to complete the removal....you better have an air tool to get the spring loaded bolts off the bottom of the header, if you dont, invest in about a 2-3 foot pipe and jack the car up off the ground, and start cranking, those are the only hard bolts to get off of the car, other than that, there isnt any other "hard" bolts to get off and the header install will go in real easily...patience oh and if you have any questions call my phone it wont cost you anything if your on a cell phone 856 904 7336
Old Nov 28, 2005 | 04:48 PM
last night i got every bolt off easy except for the bottom left bolt on the header....there literally no room to work with....a wratchet wont fit because the alternator is in the way
Old Nov 28, 2005 | 05:15 PM
dgHotLava's Avatar
you do know you can remove the Alternator if you need....
Old Nov 28, 2005 | 05:20 PM
Team No Limitz
Thats too much work...just go out and buy an offset 12 mm wrench for $10 at Sears and your set.
Old Nov 28, 2005 | 05:26 PM
PolyFM_TC's Avatar
Or use a 12mm wobbly socket with a 6" extension. Worked great for me.
Old Nov 28, 2005 | 06:15 PM
The_Instigator's Avatar
Thats what I did
Old Nov 28, 2005 | 07:15 PM
Beantowntc's Avatar
take pictures of the install if you can.....i dont think anyone has done a header write up with pics yet
Old Nov 28, 2005 | 08:07 PM
What about this one?
https://www.scionlife.com/forums/viewtopic.php?t=56520
Old Nov 28, 2005 | 09:56 PM
Beantowntc's Avatar
Hmm...well....uh.....that wasn't there when I looked....that's my story and I'm sticking to it lol
Thanks
8URAWD
May 2, 2018 02:22 PM
cacafria97
Jan 12, 2015 01:34 PM
bktply
Dec 10, 2014 05:21 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
