View Full Version : sway bars - rear only!
cowboy
04-13-2004, 10:30 PM
so, i'm a huge fan of sway bars... i put a rear one on my 2.5rs impreza and it turned if from a understeering fwd type beast, into a completely neutral, 4 wheel drift machine. now i know that the xB will never be a 4 wheel drift machine, but why put a front sway bar on? i just don't get it. i don't want more understeer.... i want less. now because hotchkiss is the only manufacture of sway bars right now, we have only had the option of putting on front AND rear. but i honestly couldn't understand putting on ANOTHER rear, and then a front to counter act the rear. doesn't make sense to me.
not to mention the added weight of adding both front and rear (and not just replacing the OEM rear). (almost forgot to mention the added install cost of the front; the rear can be done easily diy)
so i've been waiting for someone to come out with a rear only, and it seems someone is:
http://www.ptuning.com/html/search-result.cfm?cmbPriceRange=&cmbCategory=suspen&cmbSubCategory=swayba&cmbMakeModel=xB&cmbBrand=pro&cmbYear=
anyone know about "Progress Technology"? they make good stuff?
anyone care to comment on the rear vs. the front&rear sway bar? my ideal would be an adjustable rear like the whiteline one i had on my suby...
Minsk99
04-13-2004, 11:12 PM
Check this out:
http://www.scionlife.com/forums/viewtopic.php?t=10388
dinkjs
04-13-2004, 11:20 PM
Progress products are excellent quality.....defently worth the money...my dad had there springs and rear sway bar on his Focus wagon.....they were great...highly recommended
cowboy
04-13-2004, 11:24 PM
Check this out:
yeah i read that before... but it applies to the hotchkis sway bars specifically. i do think that you should install both front and rear if you buy the hotchkis -- they are created to work together. however, now that it appears as though we will have a rear only option, i wanted to get some input into the front/rear vs. only rear general debate - not in relation to hotchkis only.
i really don't want to add 2 bars, paying ~$300 installation, when i can replace 1 for free with the same (and even maybe better) affect on handling.
dinkjs
04-13-2004, 11:27 PM
The thing about the Progress rear bar is its 19 mm...that means its to replace the factory one....and the factory rear is welded on....this could be alot of work cutting the stock off.....UNLESS a big unless here the Progress is alot made to be added on like the hotchkis rear is
cowboy
04-13-2004, 11:32 PM
interesting point... i didn't know the stock one is welded on (how lame and cheap of them - but it is a cheap car). we'll have to wait to find out if the progress is added or stand alone...
Minsk99
04-13-2004, 11:33 PM
This one might be more generic discussion about the merits of front sway.
http://www.scionlife.com/forums/viewtopic.php?t=8319
cowboy
04-14-2004, 02:52 AM
anyone have any info ont the cost or release date of the progress sway bar? perhaps someone knows how much their sways are on avg...
