Cool Charge Solution for the TOTAL sleeper tC
I would like to share this nice find with all fellow tC owners
I did a long search last nite and came across this company www.alkycontrol.com and it seems that their setup is pretty unique unlike what I've come across in the past, aquamist...coolingmist...snowperformance... etc Have you all folks seen this product before?
The water/alky delivery is based on volt signals received from a 3 bar MAP sensor and as the boost starts/increases, a signal from the MAP processor causes the voltage to the pump to activate/increase and (more) pressurized water/alky mist is delivered in the charge tract.
As boost is reduced when on deceleration, the mist delivery/pressure decreases as well until the programmed set point. Eg. Set to start mist at 5psi onwards and stagnate at 7psi and pump will deliver 100+psi mixture to the nozzle constantly adjusting between this range. Below 5 psi, no water delivery. Assume this set point for the ZPI Stage 0 kit w/o intercooler. Very Interesting
The lines are in braided steel (nice bling touch
) and filter washable. The kit has that strong industrial look and built. Check valve is fail safe, overall looks sturdy and durable too. Pump used is by shuflow and the water tanks look like they can hold mixtures w/o problems in the long run
For turbo setup on 10psi and beyond, this would definitely complement or enhance the cooling effect on top of the FMIC. Think of it as sequential cooling before entering the intake plenum
May complement your PWR setup even further by reducing intake temps to 80F in the intake plenum! Allows you to dial in agressive ign timing (+1-2 degrees) and minimise knocking when in Stage 1@ 12psi = 330whp (380ish bhp) .
Hope this would fine tune the decision making to go boosted
You would need all the info you can get before deciding on the setup you want that can be both scalable and affordable in future
Did I sound anything like that?
Dang!
Sorry, but I just get excited when I find something interesting as I do intend to ask them for an application suitable for the 2AZFE platform. I would like to use that setup for the sleeper look WITH slayer capabilities
Wonder if they will be surprised that the Scion tC/Camry/RAV4 might be wanting to use their product. They seem to have made this injection kit meant primarily for domestics
I have a similar setup in my Lexus. Works real well. Just have to make sure you put plenty of safeguards like warning lights. Imagine blowing a fuse on that setup while running 14 psi or so.
Yippee
There is a similar injection user in the house.
With 600whp, no less
on a sedan......... more
Did you run w/o an intercooler or did the injection acted as a secondary aftercooler?
I agree with you on the safeguard measures but I do notice that your Lexus has a HUGE arsenal of audio ordnance AND you're pushing approx 700 to 800ish bhp at crank??
Yeah the fuse and leds woould be applicable to you
I am thinking that if the boost was less than 1 bar with no major audios on board, should not have to worry too much. Would that sound just about ok in your opinion?
Very nice find! But you may want to reconsider calling it a "sleeper" mod... I dont really consider a turbo charged car with braided steel lines pumping a water/alky injections plus a FMIC a sleeper
OOpps
I made a boo-boo.
Yeah, you're right there.
How is it possible to have FMIC sticking out and calling it sleeper....
Yes, the setup would be FMIC-less. Got the concept straight now
Guess I got a little carried away earlier, didn't pay attention and you caught me
I'm not too sure about s/c though. Different factions have different views on this. It seems that the general consensus think that the s/c did not need water injection at low boost as there isn't much heat being introduced into the intake as the driveshaft of the centrifugal blower is not really subjected to heat unlike turbo which uses hot exhaust gases to drive the opp. impeller fins to generate compressed air.
Besides, it seems that the REAL big power for s/c comes in at 18psi and above? You may need water injection at those kind of psi but I'm not sure
It would be good to speak to an experienced s/c owner who has toyed with BIG boost no. for an s/c setup
Originally Posted by sleepermod
OOpps
I made a boo-boo.
umm you can do a fmic and still have a sleeper
i know a guy with a ef9 that has a front mount painted black and it sits beind the bumper with little chanels made out of fiber glass to make the air flow to it even though it is hidden looks nice as hell and stock just required some work
As you all folks know, we're in the tropics
so weather is quite hot :
Day temps hit 90F and Night temps are at 80F with humidity levels close to 70%
Btw, an update on the alky injection. I received the email reply from the main man and he actually does alot of business with the DSM and EVO crowd...
uummmm.... Maybe that's why they have an edge. Their secret weapon is out in the open
Time to level the playing field
Then you never get a chance to be SICK and TIRED of COLD. Snow here, mid 20's
Originally Posted by toastbox
ScionDad,
send some of that stuff this way!! I'm tired of working and need a free day off
