xB Fender Flares?
Old Dec 10, 2005 | 09:42 PM
buymorescions's Avatar
Default xB Fender Flares?
Anyone know were I can find some fender flares for the xB?
Old Dec 10, 2005 | 11:14 PM
suspended's Avatar
check out http://www.bbist.com
or for universal flares (you will need modifications done), check out http://www.teamprototype.com
Old Dec 11, 2005 | 02:25 AM
MattyRattyPoo's Avatar
bBist does not have them in production right now but you can check out cftype.com for xB carbon fiber fender flares.
Old Dec 12, 2005 | 04:55 AM
RockCrawler's Avatar
pricey but nice.
Old Dec 12, 2005 | 07:24 AM
Max2k's Avatar
Are you planning on running insanely wide wheels?
Old Dec 12, 2005 | 07:29 AM
bBOXD's Avatar
so.... Are you??
Old Dec 12, 2005 | 03:57 PM
Thanks
Old Dec 20, 2005 | 11:38 PM
spongebBox's Avatar
if you were to get flares...what would u recommend as far as wheels ?? size? camber? shoot i dont know...but i do see that you would wanna pull the wheels out cuz ur ride would look like its floating.
Old Dec 21, 2005 | 01:59 AM
ctruss's Avatar
If you get flares you will want to go with some serious dish.
A couple common wheel widths and offsets for use with flares are....
8" wide wheels all around with 20-25mm offset up front and 10-15mm offset out back
I have also seen 8" wide up front, 20mm offset with 9" wide in the back with about 20mm offset.
I once did 8.5" wide up front with 15mm offset, and 10" wide out back with a 20mm offset on my GTI.
Old Dec 21, 2005 | 07:27 AM
spongebBox's Avatar
sounds nice.. icuz i been wanting and plannin to get flares..i jus wonder how much matching wheels would be?? any ideas?
Old Dec 21, 2005 | 01:08 PM
ctruss's Avatar
Alot.
WORK wheels you see on xB in here can cost $1000-3000 just for the wheels.
Not sure they make them in 4-100 bolt patterns, but there is a place called tunershop.com over in europe that has several deep dish wheels in the $800-1500 price range as well as more expensive ones.
Old Dec 21, 2005 | 01:20 PM
Subcompact Culture's Avatar
I really like these flares.
Those aren't insanely wide wheel, though. 15x7 SSRs. I really like this look.
Old Dec 21, 2005 | 01:23 PM
suspended's Avatar
I just don't like how any flares in the US i've seen don't go onto the flare on the back door, if you mold them, i'm not sure how that would look.
Old Dec 21, 2005 | 03:01 PM
sexyscionlover's Avatar
yea i agree wayne. if people flare them out, i think it would make sense to spend some extra time and do some custom work on the door to match the flare its next to .
for flares you can run as low as 15x8 with -10 offset or so and be fine, or do like shelby and have 15x9s with -25 offset. it all depends on the flare and how flush you want to be.
scott
Old Dec 21, 2005 | 07:13 PM
bBOXD's Avatar
Sorry but those specs can fit under the stock xB fenders. Those will not fill the fenders at all. You need to go wide when running flares. You can run at least 2-3 inches wider then what the stock fenders allow.
Personally for some flares i would run specs pretty close to Genes old xB. Something close to a 9" -25, which Scott has mentioned.
IMHO for flares this is what i would do.
9" -25
10" -15
Yes those are negative signs. Those will really fill out the flares and look incredible. You would definately need to cut out the metal fenders for the wheels to flex under the flares. And of course GET REALLY LOW.
Old Dec 22, 2005 | 12:57 AM
spongebBox's Avatar
thanks for the advice mark..i'll definitely refer to u if i do this project
Old Dec 22, 2005 | 01:12 AM
squirrel's Avatar
Go Q! Go Q! Go Q! Go Q! Go Q! Go Q! Go Q!
Old Dec 22, 2005 | 04:54 PM
ctruss's Avatar
9" -25
10" -15
Sorry, but thats LESS dish that the wheel sizes I was talking about.
If you go with a 9" wide wheel, you will need roughly -25mm offset in the front and -20mm in the rear. If you do 8" wide wheels you will need roughly -20mm offset in the front and -10mm offset in the rear.
As you increase that negative offset number you will have less dish and the wheel will not stick out as far.
Example: Most sport compact cars or FWD cars in general (including our xB's) have wheels with an offset of -33mm to -40mm.
Old Dec 22, 2005 | 05:04 PM
suspended's Avatar
9" -25
10" -15
sorry bro, but thats incorrect...offset goes from where the mounting hup is in comparison to the width of the wheel...example:
lets say you have an eight inch wide wheel and you have a zero offset, that means the mounting hup will be right in the middle of the wheel (basically giving you 4" or so of lip)
positive offset numbers means that if you have a +5 offset, your mounting hub will be 5mm towards the outside (the dish) of the wheel from the center
negative, is the opposite, negative 5 offset, the hub would be 5mm from the center towards the inside part of the wheel, hence making the dish 5mm larger then a 0 offset.
if thats confusing to anyone, i can draw a diagram, most stock offsets for fwd are around positive 35-40mm give or take a few
Old Dec 22, 2005 | 06:08 PM
Boxer_Rebellion's Avatar
Here's the only xB with those type of flares done right-
