17's with 215-45-17tires...is this set up ok on the box?
Old Dec 12, 2005 | 03:24 AM
DeansBlackBox's Avatar
Default 17's with 215-45-17tires...is this set up ok on the box?
I'm buying some wheels this week and I just wanted to make sure that this tire size is going to be ok. I want the thickest sidewall possible and I've been told that a 45 series tire will be fine on a 17. Can anyone confirm this for me?
thanks for the information.
d
Old Dec 12, 2005 | 03:48 AM
Squishy's Avatar
I have 40's on my xA and I have tons of room to spare. This past weekend, i talked with a guy with an xB who had 17's with 45's and the TRD 1" lowering springs, his road fine and had room..no rubbing.
Old Dec 12, 2005 | 04:42 AM
x_rayted711's Avatar
I have 45's on my xB. Plenty of room and mine is with TRD springs. Mine are 205/45. Yours will be slightly wider and slightly taller, but should fit no prob.
Old Dec 12, 2005 | 04:46 AM
Boxer_Rebellion's Avatar
That is the best combo going IMO. I have em with the OTG shims and a 2" drop with no rubbing. Much better ride than 40-series I previously had.
Old Dec 12, 2005 | 04:56 AM
randomsuper's Avatar
not to hijack, but would 225/45 fit on a s tech lowered xa? just wondering since i was planning on installing the same size tire deansblackbox is looking at but wouldn't mind something a little wider.
Old Dec 12, 2005 | 05:01 AM
I don't know for sure on the 225/40. I do think they may be too tall and will deffinitely throw off the speedo as well as more strain on the other drivetrain parts. Just a heads up!
Old Dec 12, 2005 | 05:09 AM
Squishy's Avatar
What's the drop of those...i have goldlines with a 2" drop and dude I could easily the 45's..easily. I wish I had 45's but when the tires need replacing I'll change. I could have gone 18's with 40's if i was going to run 40's.
Old Dec 12, 2005 | 05:15 AM
i have some adr 18's with 215/35 tires right now and i hate it. the car has a lot of road noise and you feel every bump. plus the handling has gone to hell. so i bought some forged 17's (15 lbs!) and want to put on some fairly large rubber. i think 225/45 would look nice and mean on my little car but i just wanted to make sure i won't rub or anything.
and the s techs dont lower the car 2 inches so i think i'll go with the 225 unless i find out i'll run into some problems.
Old Dec 12, 2005 | 05:27 AM
Squishy's Avatar
I can't be positive 225 will fit or work, but 45s i know would. I hear you on the road noise, man i totally know if the highways is crappy in some areas. i also hate watching for potholes and cringing. I just wish i had a little more insurance sometimes.
Old Dec 12, 2005 | 05:29 AM
squirrel's Avatar
215/40-17 are close to the OEM rolling diameter if staying w/ a 7 or 7.5 inch wide wheel. 215/45-17 will work if stretching it on 8.5 inch wide wheel. 225s are a bit too tall.
Old Dec 12, 2005 | 06:24 AM
bB2NER's Avatar
Music City Scions
My new tires are 215/45/17's and can't wait to see how much better they will be than the 205/40's.
They will fit without any rubbing as long as they are on 17x7 rims with roughly 40 offset.
The speedo will read slightly lower than actual speed.
Old Dec 12, 2005 | 06:30 AM
My 205/45 was the closest to stock in a 45 series tire...I just couldn't go with a 40 series...The dealer was pushing us hard to buy them too!
Old Dec 12, 2005 | 07:54 AM
iNFEktEd's Avatar
im running 215/45-17 on a 8.5 wide... if i had to do it again, i'd rather go 215/40 or even 205/40.. here's a pic.
Old Dec 12, 2005 | 12:01 PM
Peter_Rabbit's Avatar
although 215 17 40 will fit you have to get the correct offset on the wheel or there will be some rubbing in the front. i have 215 17 40 with +42 offset and they rub when turned all the way left or right
Old Dec 12, 2005 | 01:33 PM
iNFEKted- any side pics of those wheels? They look killer from the front shot...
Old Dec 12, 2005 | 09:48 PM
iNFEktEd's Avatar
this is the only pic i have of them that's a side shot.
Old Dec 13, 2005 | 01:10 AM
Those are the D2's right? Can't believe that's the first time I've seen em on an xB. Looks hot.
Old Dec 13, 2005 | 01:26 AM
iNFEktEd's Avatar
thanks... and yup, those are them...
Old Dec 13, 2005 | 01:33 AM
O5Toaster-xb's Avatar
These are 205/40/17's This combo makes the set just a bit smaller diameter than the stock tires, i may be changing to the 215/40/17's..... to get the most out of them, ie; gas mileage, speedo more correct ect. I have a +40 offset with no problems
http://www.1010tires.com/TireSizeCalculator.asp This link is good for looking at all the specs for size comparisons.
Old Dec 13, 2005 | 03:32 AM
bBOXD's Avatar
Shoulda asked me first bro! I would never recommend fatty bulgy tires to anyone. A 205/40 would look incredible on that wheel. Of course its all dependant on how low you are willing to go. Looks good though.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
riotmonkey85
Mar 6, 2015 05:22 PM
ninja_steph
Feb 5, 2015 02:50 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
wizzlexB
Dec 27, 2014 04:06 AM
