help me just odered 18" x 8
Either way you are pushing the wheels out further than stock. +35 will be more flush the the +38...but its just 3mm...not all that noticeable. Im going +35 when get my rims but more for BBK clearancee and the fact they only have the wheels I want in +35 or +45
Do you guys think that a 45 offset on a 18"-8" wheel will be sitting too far in the wheel well? Ive been looking into this wheel i want but thats the only offset offered. Also what would be the best tire size for an 18-8?
Thanks!
Thanks!
You can use this calculator to see what the wheel offset will change:
http://www.1010tires.com/WheelOffsetCalculator.asp
it looks like it will extend the outer lip by approx 13mm which will set it out quite a bit further than stock.
You can also use their tire size calculator to check on tires
http://www.1010tires.com/TireSizeCalculator.asp
Something in a 225 or 235 in a 35 series will probably work well.
A 235/35-18 will be about as close to stock overall diameter as you can get.
Let me ask you this. If you have a 17"-8" wheel with a 45 it would be the same as a 18"-8" with a 45 offset right? Like as far as having the wheel tucked in. Cause there are 2 guys on here that have this same rim but 17"-8" with a 45-46 offset and they say it sits flush???
No..an 8" wheel with a +45 offset will stick out 13mm further on either side than a 7" wheel with a +45 offset. Remeber you have 1" of extra wheel to work with.
You can see the numbers by typing the dimensions on the wheel offest calcualtor here: http://www.1010tires.com/WheelOffsetCalculator.asp
I knew that a 7" wide wheel compared to a 8" wide wheel would be different but My question is if it matters if its a 18"-8" or a 17"-8" Both being 8" wide?
Thanks For the help! IM a first timer with this wheel stuff
It will end up being about 1/2" taller than the stock setup. Im not too sure about the clearance with you being on S-Techs..You may want to PM some people that have those springs with 18s and see if they have any problems.
