ECU questions
Does anyone do reflash on the ecu for bolt ons? Anyone running any control units that have inputs if they are worth buying, ie comcon, emanage, unichip? If so which control units and what will they control ie ignition timing, fuel curv, and vvti (I am aware most will do ignition and fuel curvs)? If anyone has similar mods running a control unit what is the gain from it? My mods are at the bottom in my signature block. Thanks for the help
A Good Tune will almost always result in more HP with an engine managment setup....
There are a few threads of camcon users and emanage users floating around... I'd search a bit to see if you can find what you are looking for...
Rest assured that you'll not only have to fork out the cash for the engine management unit, but also for the neccesary dyno time to tune it out...
I'd also suggest A/F guages and such to ensure your tune doesn't run the engine too lean or rich....
Cost wise, it's best to wait until you do some larger mods to get the most out of a managment setup... FI - P&P Head/Pistons/Intake Manifold...
a lot of your tune will depend on how far you want to go with the car. If you are looking to do heavy duty mods, i would suggest going with a full E manage unit. If youre going to be doing your basic bolt-ons, then im going to say the camcon is more than enough to tune your engine, but emanage can still be used.
a good tune will not only unleash your engines potential, it will save your engines behind!
i would say a reflash when a company decides to start doing them will be the best easiest and probly cheapest option unless your going all out with a completely rebuilt engine or some sort of F/I you wont need a stand alone
bootlgr
Jan 26, 2016 01:22 AM
