View Full Version : Where is a 12V source under the dash?
IceBox
10-26-2003, 03:30 AM
I recently bought some blue light up pedals, but I can't find a 12v Power source under the dash. I looked under there and saw many wires :shock: and I was stumped :roll: . I ended up hooking up a 12V lap battery to it, but I hate having giant battery on the floor :x . Anybody have light up pedals and have found this or does anyone just know?
IceBox - EDDY
sithscripter
10-26-2003, 03:52 AM
The fuse box is right by the pedals. A fuse tap might work. I've never used one myself -- anyone out there have first-hand experience?
IceBox
10-26-2003, 04:24 AM
I tried to find my way around the fuse box, but I got nowhere. What I really want to do is find the light switch connection, so the pedals would go on when I turn on my lights. I could still use the switch too, but I haven't decided what to do yet :? , but i need power first
IceBox - EDDY
Dan_eboyfrom310XB
10-26-2003, 04:27 AM
i justin stalled a neon light to my motor bay; and i just hooked up the positive of the light to one end of a switch and gounded tha ground and hooked up a line to tha battery that went to tha other side of tha switch and it worked if you want to do that or ill show you on sunday
tha costco man
IceBox
10-26-2003, 04:34 AM
Hey Daniel,
I didn't know it was you untill you said "Costco man". Thats funny. I know what you mean by the switch, I have one, but how do I get to the battery from the bottom of the dash? I installed some underbody lights to the battery, so I figured out how to use the battery and how to ground the wires, but I only could find one hole that goes from the dash to the hood, but it tight rubber around it and I cant fit one more wire through. How did you get your neon light wires through to your battery?
IceBox
10-26-2003, 04:40 AM
ANybody else got any ideas?
IceBox
10-26-2003, 06:55 PM
ANyone else have ANY experience with using 12V of power under the dash?
bBted
10-27-2003, 12:54 AM
u can tab the wire to the side mirrors control...
pull out the little fuse door and u can reach the back of the mirrors control...
bluxb
10-27-2003, 02:22 AM
under the center console where the shifter there is a blue wire harness with a green wire. tap that wire for your positive and your pedals will come on with your lights
sithscripter
11-04-2003, 04:35 AM
One of these might work.
http://www.partsexpress.com/pe/showdetl.cfm?Product_ID=1527&DID=7
