camber? trd springs?
Old Apr 21, 2004 | 09:34 PM
supitsmark's Avatar
Default camber? trd springs?
do i have to worry about camber/caster if i get the trd springs installed? what experiences have you guys had?
Old Apr 21, 2004 | 10:05 PM
elzy0000's Avatar
you dont have to worry about this at all with the trds... check out my profile
Old Apr 21, 2004 | 10:32 PM
bBted's Avatar
dont worry...most people are running 2" drop
Old Apr 21, 2004 | 10:36 PM
Munch's Avatar
There are many threds about this topic. That little SEARCH feature works wonders here. You don't need and adjustment.
Old Apr 21, 2004 | 10:48 PM
randode's Avatar
Wagonistas
Default Re: camber? trd springs?
the camber/caster will be fine. The ride will be harsh though, and not low enough. Get some 2" springs!
Old Apr 23, 2004 | 12:06 AM
scionxb04's Avatar
on the rack it showed me as having -1.1degrees of camber after droping my car 1.8inches...
Old Apr 23, 2004 | 03:00 PM
randode's Avatar
Wagonistas
this is quite possible. what i'm saying is there is no way to adjust the camber.
Old Apr 23, 2004 | 08:43 PM
scionxb04's Avatar
the rear tires cant be adjusted....but u can buy a kit for the fronts to adjust camber....u might wanna research your answer.....the guy who did the alignment on my scion said they make camber kits for the front if i wanted to correct it he could order them...but at -1.1 i wasnt worried.....
and i know someone on here was making plates to adjust camber for the rears....if u fliped his plate over you would have +camber in the rear....so i see no problem adjusting for camber....
Old Apr 23, 2004 | 09:27 PM
randode's Avatar
Wagonistas
this is true. what i'm saying is from the factory, there is no camber adjustment.
DJ_FroZone
25
May 30, 2019 07:17 PM
danielv
Aug 26, 2015 07:14 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
JPuehl
Jan 10, 2015 01:01 AM
minter66
Dec 15, 2014 01:45 PM
