**Alphawerk header install
How many people with the alphawerk header used both of the brackets at the bottom of the header? I altered the brackets and got new bolts so i wuld reuse them. I would assume that it would keep some of the weight off of the head and minimize cracking in the long run.
if you're talking about the black (mine are black) side brackets that connect to the header, no i didnt use them. the header seemed like it didnt fit so snugly to the s-pipe, even when the spring bolts were fully compressed. when the car ran there was no sound of exhaust leak so i guess the gasket did its job. i actually removed the side brackets. it wasnt hard but also wasnt easy since the bolts are placed in odd positions. reason i took it out was cuz i thought there would be some issues with vibration in there. that might have lead to "rasp". after the install i had absolutely no rasp. my header sounds great!
I used the driver side bracket.. Had to mod it with bolt though.. The stock bracket wont bolt on to the alphawerks header because the hole isn't threaded... couldn't get the passanger side bracket on so I left it off..
Originally Posted by Jarrod123
what is the purpose of the brackets if you really dont need them?
TheRedBox
31
Dec 2, 2003 04:53 PM
