Installed Megan Racing S-Pipe
Old Dec 28, 2005 | 02:01 AM
corpan32's Avatar
Default Installed Megan Racing S-Pipe
I received my Megan Racing S-Pipe from upscaleautomotive.com today and put it on because I was bored. Great fit didn't have any problems and I have stock header and catback. Easy install only took me about an hour in my garage. Overall great product. Can't wait to get the Megan Racing Catback on and then really feel the gains.
I did have one problem tho I through a cel. Do i need the antifouler mod to fix that?
Old Dec 28, 2005 | 02:02 AM
WeDriveScions's Avatar
That should fix it up just right.
Old Dec 28, 2005 | 02:10 AM
corpan32's Avatar
You always know the answer to my questions wedrivescions.
Old Dec 28, 2005 | 02:12 AM
It's what I do..... I've never seen a s-pipe setup without changing the headers, but the relocation of the stock sensor probably gives it a little too high of a reading.... so pulling it out of the stream a bit, using the antifouler trick, should fix it up just right.
Old Dec 28, 2005 | 03:06 AM
corpan32's Avatar
Aight thanx
Old Dec 28, 2005 | 09:21 AM
tikbhoy's Avatar
did you use the spacer that it came with ?
Old Dec 28, 2005 | 02:09 PM
corpan32's Avatar
Ya I put the spacer between the spipe and the mid pipe.
Old Dec 28, 2005 | 03:10 PM
corpan32's Avatar
After driving last night i get in my car this morning and CEL is gone. Should i still buy an antifouler are is everything fine now?
Old Dec 28, 2005 | 03:16 PM
If it doesn't come back, don't worry about it.... If you get it back again... it'd be a good idea.
Old Dec 28, 2005 | 03:35 PM
jmiller20874's Avatar
You got a CEL with the stock header? Yeah like he said if it stays off, it'll be fine. If it comes on again, get that code read.
Old Dec 28, 2005 | 03:37 PM
corpan32's Avatar
Aight thanx
Old Dec 28, 2005 | 04:15 PM
Shifty's Avatar
I've had the CC S-Pipe on for a month now with stock header and exhaust.
No cell and now I'm ready for when I get a full exhaust.
Old Dec 28, 2005 | 04:49 PM
toyota_scion_tc's Avatar
the s-pipe alone should not set a cel. Check the code and reset your ecu to see if it stays gone. I think you might have caused another problem if it is throwing a cel.
my06tc
Jun 25, 2015 12:18 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
