View Poll Results: which offset would be better
19x8 45
40.00%
19x8 35
60.00%
Voters: 10. You may not vote on this poll
whats better offset 35 or 45 ?
Old Dec 29, 2005 | 05:11 AM
rolstc's Avatar
Default whats better offset 35 or 45 ?
im going to get 19" rims. Now im lost for offset. which one would be better for the Tc.
19x8 35
19x8 45
Old Dec 29, 2005 | 05:27 PM
Ninja4Hire's Avatar
With the 45 ET on a 8 in wheel, your looking at 13mm less clearance on the inside with an extra 13mm sticking out.
With the 35 ET your going to get 3mm less then what you have stock with a fat 23mm more as far as sticking out goes.
So basically if you like your wheels more flush with the car, get the 35 ET. Plus the inner clearance is better if you end up getting a big brake kit.
I just got 18x7.5 35ET Konig Tuner II wheels but I have'nt put them on yet, cuz I want to install my springs first
Old Jan 1, 2006 | 01:38 AM
simplespirit's Avatar
An 8 inch wide wheel with +35 is going to rub. For an 8 inch wide wheel +45 to +48 is optimal.
Old Jan 1, 2006 | 03:08 AM
taek's Avatar
35 is the better offset.
33 is flush
-taek
Old Jan 1, 2006 | 12:15 PM
What size tires are you looking at? If you stay with a 215 you might be ok with a +35 but any wider and you're going to rub on inside of the fender lip.
Try this post for all you ever wanted to know about offset: http://www.yoursciontc.com/forums/in...showtopic=8327
Old Jan 2, 2006 | 05:36 PM
raamaudio's Avatar
Correction, you will be fine with 18x8 +35mm offset as long as your tires are not to wide. I run 17x8 +35 with 235/40/17s and do not rub.
I have done a few things to check some handling issues like run zero rear camber and had the car dropped almost all the way on the coilovers, only then would it rub over really big bumps in the rear and barely touched.
You will not have zero camber if dropped, some negative camber is dialed in from the factory at the stock height and you gain more when lowering the car.
17 vs 19 is not going to make much of a difference, again as long as you go with a reasonable tire width, 225 width may be a good plan to stick with.
If you want a wider wheen the you need to have a higher number +offset.
Rick
Old Jan 3, 2006 | 02:35 AM
yamaha16bw's Avatar
Will 10mm really much different when install on the car? Ive got this rim I really want 18x8 with a +45 offset. I dont really need it to be flush just better lookign the stock. Any input would great
Old Jan 3, 2006 | 03:08 AM
The_Instigator's Avatar
18x8 +45 should fit just fine.
Old Jan 3, 2006 | 04:59 AM
wayne33's Avatar
I have 18x8 with 35 offset. i have s-tech spring and no rubbing issues
Old Jan 3, 2006 | 05:59 AM
jay_jay_n's Avatar
anybody kno if 19x8.0 with +43mm offset rub on s-tech?
Old Jan 3, 2006 | 10:03 AM
19x8 will probably be fine if you don't go wider than a 225 tire. If you do want wider, you're going to rub with that offset.
Old Jan 3, 2006 | 10:06 AM
Correction, you said +43 so you're probably ok up to a 235 or maybe even a 245 tire.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
