enriquetc
12-31-2005, 11:58 PM
http://i13.photobucket.com/albums/a263/enriqueonnos/motorlegal.jpg
heres a pic of my motor.
View Full Version : my custom turbo kit enriquetc 12-31-2005, 11:58 PM http://i13.photobucket.com/albums/a263/enriqueonnos/motorlegal.jpg heres a pic of my motor. WeDriveScions 01-01-2006, 12:13 AM Cool.... a different setup for once..... Looks a lot different that the other setups out there. Kenshin 01-01-2006, 01:48 AM Your in miami right? WeDriveScions 01-01-2006, 01:57 AM enrique sup... i was that guy that came up and asked what you were dropped on at westland over the xmas holiday.. Dang close... isn't westland mall near hialeah gardens? taek 01-01-2006, 02:25 AM dammm. clean xterior and crazy engine. :bow: -taek Dakahn 01-01-2006, 04:35 AM What kind of #'s are you running, doesn't have the exact... aprox. works w/me! Very nice, very very nice. kungpaosamuraiii 01-01-2006, 08:41 AM A proper turbo manifold for once zer0 01-01-2006, 03:29 PM A proper turbo manifold for once Agreed, who makes that manifold? enriquetc 01-01-2006, 07:20 PM all the things that are not universal were custom made, the manifold was made out of regular piping then sent to a shop to make out of cast iron and there it is. DuMa 01-01-2006, 08:37 PM spec list for the turbo kit please and how much whp and psi are you running? KurtRS1 01-02-2006, 09:08 PM Cool kit :clap: I also am doing a custom kit and would like to know what parts you used and how it runs? Any problems? so I can avoid any you know of. :bow: mattssi 01-02-2006, 11:33 PM Spec's yo kirill 01-02-2006, 11:48 PM What is your fuel management? enriquetc 01-03-2006, 03:53 AM e-manage mattssi 01-03-2006, 04:01 AM a man of few words kirill 01-05-2006, 01:28 AM e-manage How hard was it to install and tune? And no bigger injectors? zer0 01-05-2006, 01:32 AM e-manage How hard was it to install and tune? And no bigger injectors? ZPI and Dezod make Plug and Play harness's for the emanage. No hacking/splicing up your factory harness. :) Also concerned about the fuel system of this ride... :nails: enriquetc 01-05-2006, 01:38 AM naa i had to wire up the emanage myslef toyota gave me a whole prinout of the ecu and i went from there for fuel im running on ???dsm injectors??? walbro fuel pump zer0 01-05-2006, 01:43 AM 450 stock DSM injectors?? Should be perfect for 300 whp. 255 Feul pump for safety works too.. What is your feul pressure set at? Stock? kirill 01-05-2006, 01:54 AM naa i had to wire up the emanage myslef toyota gave me a whole prinout of the ecu and i went from there for fuel im running on ???dsm injectors??? walbro fuel pump I did not think that tC can use additional fuel pump How did You by-pass that fuel regulator before fuel rail? If You didnt, it would still keep the same stock pressure to the injectors, right? kirill 01-05-2006, 01:56 AM e-manage How hard was it to install and tune? And no bigger injectors? ZPI and Dezod make Plug and Play harness's for the emanage. No hacking/splicing up your factory harness. :) Also concerned about the fuel system of this ride... :nails: Thank You, Thats what I probably need sensay 01-05-2006, 04:07 AM custom manifold huh... that looks an awful lot like the rev-hard manifold... evo_tC 01-05-2006, 06:29 AM actually its different i have the rev hard manifold on my car rampage1003 01-07-2006, 01:00 AM can they make another one and how much would it cost all the things that are not universal were custom made, the manifold was made out of regular piping then sent to a shop to make out of cast iron and there it is. rampage1003 01-07-2006, 01:00 AM can they make another one and how much would it cost all the things that are not universal were custom made, the manifold was made out of regular piping then sent to a shop to make out of cast iron and there it is. Buebie 01-07-2006, 01:43 AM Looks good. What psi? What bov you using? Also, not hating, just saying, you may want to ceramic coat the mani for heat reasons. Or thermal wrap it. PghtC 05-24-2006, 02:08 AM cool soros151 05-24-2006, 08:23 AM Meaning to do a custom turbo kit too. This thread helps. Thanks. |
