blacking out the front emblom and grill
Old Jan 3, 2006 | 10:11 PM
asthmatic's Avatar
Default blacking out the front emblom and grill
what would i need to paint the silver boarder around the front top grill and the emblem black? What would i need to do to prepare for this.
Old Jan 3, 2006 | 10:23 PM
IndigoTC's Avatar
MN Scions
take the grill out. take the trim peice off and take the emblem off. sand the trim and primer then paint, and maybe add a clear coat
Old Jan 3, 2006 | 10:27 PM
WeDriveScions's Avatar
Please use the search tool to get info on painting the front emblem/grille....
You need some good paint.... Krylon Fusion is good for plastic and you need to wet sand the area prior to laying down the first coat to help it stick... take your time, lay down thin coat after thin coat and then lay a couple clear on after your done....
Old Jan 5, 2006 | 12:34 AM
Phixeus's Avatar
hows this?
Old Jan 5, 2006 | 03:15 AM
The_Instigator's Avatar
Sanding is not required. Start by cleaning everything well with soapy water. Apply a few coats of duplicolor adhesion promoter and then duplicolor auto paint of your choice. Follow up with a few coats of duplicolor clear coat and you will have this:
terrye
Jul 11, 2015 10:40 PM
2006sciontcva
Scion tC 1G Aero & Exterior
Jan 7, 2015 01:51 PM
minter66
Dec 15, 2014 01:45 PM
randomsuper
Dec 5, 2014 11:14 PM
umnitza
Dec 1, 2014 06:26 PM
