Automatic OBX speed star shift knob install question
Old Jan 4, 2006 | 01:46 AM
Mica's Avatar
Default Automatic OBX speed star shift **** install question
I only want input from people who have installed the speed star shift **** on their automatic tC's.
I'm trying to install the 8mm plastic insert into the shift ****, but it seems too big to fit. Anyone have any tips to get this in?
Figured this would be an easy job... installed a shift **** in my other car in under 60 sec.
Old Jan 6, 2006 | 12:58 PM
atomicwaste's Avatar
I'm having the same problem. It doesn't seem to want to fit. Where did you buy your ****?
Old Jan 6, 2006 | 05:18 PM
krdshrk's Avatar
I have the OBX Classic leather. I had that plastic insert too. I popped it in, pressed with a bit of force with a wide screwdriver, and it screwed in eventually.
Old Jan 6, 2006 | 06:05 PM
I did try that, but the plastic part is significantly wider than the threaded area within the ****..no budging. *shrug*
Old Jan 6, 2006 | 06:52 PM
krdshrk's Avatar
Might be different on the Speed Star. Does the plastic piece screw onto the shifter post ok? Whenever I unscrew my ****, that plastic piece stays on the shifter post. Maybe put it on there and then push the **** down hard and start turning?
Old Jan 6, 2006 | 06:59 PM
I can fit it onto the post, but it doesn't even come close to fitting into the **** tho. I turn and turn and slivers of plastic come falling out....
Old Jan 6, 2006 | 07:36 PM
Syxxpac's Avatar
Team No Limitz
Scionetics
did you switch the bottom piece with the automatic adapter? there should be 3 pieces... the ****, and 2 connectors (one for a/t and the other for m/t). mine had them anyway. just a thought. i have a m/t so i didnt have to deal with the plastic piece.
Old Jan 6, 2006 | 08:03 PM
Yeah I did use the A/T adapter.... no dice- it doesn't secure into the ****.
Old Jan 6, 2006 | 10:48 PM
Syxxpac's Avatar
Team No Limitz
Scionetics
oh n/m i see what you are saying now
Old Jan 7, 2006 | 08:39 PM
Ok, I called the dealer I bought the **** from and after a day of researching the problem, they realized that the ***** have been shipping with the wrong plastic adapter. They said that all of their inventory has this same problem, but they will be shipping me the proper one.
Old Jan 8, 2006 | 12:00 AM
NGs_TC's Avatar
Where did you get yours from?
Old Jan 9, 2006 | 04:39 PM
Mica's Avatar
Thanks for the update!
I knew I wasn't crazy... I got mine from McGeorge, guess I'll give them a call.
Old Oct 1, 2006 | 08:09 AM
FLEA's Avatar
I just got my OBX Speed Star shift **** for my AT tC. It screwed on perfectly fine, but the "OBX" imprint is not on the top of the ****. Anyone got the same thing?
Old Oct 1, 2006 | 08:14 AM
tC9o9's Avatar
i dont see why you guys are having problems.
their are three pieces like andrew said.. the m/t trim piece, the a/t trim piece, and the plastic white adapter.
first you want to screw on the plastic white thingy.. it cant really be screwd on, just jam it in their with a flat head screwdriver and hammer.. it works.
second screw on teh a/t piece onto the shift ****.. it is the one that gets narrower at the end, not a flat circle.
then you just screw it onto the a/t stick, and kind pound it on if it still decides not to screw on.
then the OBX logo may or may not be alligned, if so, it comes with an allen key so you can adjust it.
Old Oct 1, 2006 | 09:32 AM
FLEA's Avatar
I got the install done in like 30 seconds. I got the AT/MT pieces, the metal adapter, instructions, but no key....just curious where did you get yours from? How long ago?
Old Oct 1, 2006 | 09:49 AM
tC9o9's Avatar
got mine at my local dealer: Puente Hills Toyota.
got it about 1-2 months ago
Old Oct 1, 2006 | 10:20 AM
SquallLHeart's Avatar
due to some crappy issues with the plastic adapters, obx made upgraded brass ones
new ***** should come with that adapter instead.
Old Oct 1, 2006 | 09:21 PM
mike6789k's Avatar
meh... it worked fine for me... 2007 auto tc... dont know what exactly the problem is
Old Oct 2, 2006 | 04:12 AM
FLEA's Avatar
I'm just saying the top of my **** (doesn't sound good) doesn't say OBX on it. Makes me wonder if I got a knockoff or the real OBX ****.
Old Oct 2, 2006 | 05:50 AM
mike6789k's Avatar
what does the box look like? did you get it from a dealer?
probably a knockoff.
