View Full Version : zpi crank pulley installation?
bluenjsciontc
01-05-2006, 10:10 AM
ok well last night i took a crack at it i got everything off and whatnot , put the car in gear but the funny thing is ...when i went to remove it ...the motor still cranks with it ...so i dont know what im doing wrong...i called my friend nick up and he says i need to get a crank pulley puller to remove the crank pulley from the car ...is this true?
nester
01-05-2006, 01:47 PM
put it in gear and it still moves? You have an automatic, don't you? Yeah, that won't work. :)
There are a few different types of pulley pullers.. If he's speaking of a puller that will hold the pulley and keep it from spinning, then yes.. that would help.
bluenjsciontc
01-07-2006, 05:52 PM
no i have a 5 speed, no matter what gear i put it in it still rotates ....unless im missing something? like a way to lock the motor because all i do is rotate the block not the bolt ...
jiujitsuking
01-07-2006, 06:07 PM
I had the same problem. Some people are saying that putting it in gear locks it and allows you to move it but that is not the case. I ended up taking it to a mechanic since you need impact tools. It cost me $80 but I know it's done right. You cannot do it with normal hand tools.
Harmonic_tC
01-08-2006, 05:49 AM
yeas, you need to have an impact wrench to remove that bolt. there is no other way really unless you get a strap wrench and have a friend hold the pulley while you remove the bolt. The best way is an impact wrench, air or electric
bluenjsciontc
01-08-2006, 10:48 AM
if i could find a place in NJ to do this for me, i would give them a call but theres no place thats like around the corner, and i dont feel like waiting 2 weeks for my air compressor :(
