View Full Version : What CAM I expect from this mod?
Minsk99
04-27-2004, 05:26 AM
I have seen in some posts mention of upgrading the camshaft. So could someone please explain how this mod increases hp (especially low end torque as has been mentioned a few times). I understand the basics of how a camshaft works however I don't know how a modified cam would be different then stock. Will it be stronger and lighter or will the actual timing of the valves be changed to let in more or less air and fuel? I would think that if this was the case that the fuel system would need to be changed as well to maintain a/f ratio etc. Anyway, if some one has the 411 and the inclination I'd appreciate the schoolin. Thanks.
Tamago
04-27-2004, 11:45 AM
well you can't really cam a VVTi engine dude..
jdaniels
04-27-2004, 02:16 PM
Why the hell not? Might be a little more involved... but I don't see why it wouldn't be possible.
04-27-2004, 04:56 PM
sure you can, but it is still in the works. And you would need a comtroller for the ECU, thats why its still in the works.
its_ikon
04-27-2004, 07:25 PM
you can. you just need to drop the variable valve timing and set-up to run more all motor. it is not worth it unless you are going for big power.
Tamago
04-30-2004, 11:51 AM
why are you arguing with me then?
at THIS POINT.. you cannot cam a VVTi engine..
same goes for your post sam, yes, you can disable VVTi, but then it wouldn't be a VVTi engine now would it?
Minsk99
05-01-2004, 05:23 AM
So, lets put aside the VVTI thing for the time being. In general, whether or not its in our engine, what properties are typically modified in an aftermarket camshaft which allow it to deliver more hp?
TheScionicMan
05-01-2004, 07:04 AM
Here's more than you want to know probably:
http://www.7ent.com/images2/ElginCamshaftArticle.pdf
Kinda answers your question, but also shows that its part of a larger combination of things.
Minsk99
05-01-2004, 07:43 AM
That was just what I was looking for. Thanks.
