installing dual halo head lights
ok before any one says something i have already done a search
i am looking for a how to on installing dual halo headlights i have a pair coming in soon
thanks
morningman
thanks
morningman
Yeah, If I remember correctly you take the bolts on the inner fenders out, next the grille out & undo the bolts behind the grille. You can tip the bumper down very carefully & access the lower & corner bolts. That is how I did mine.
If you are not comfortable with that you may want to remove all of the lower bolts as well & remove the whole bumper.
You will see, it is really simple :D
Here refer to this post for help on the bumper
https://www.scionlife.com/forums/vie...=bumper+remove
Good Luck
Good Luck
plug in play type just plug an the black an yellow wires are for the halo's and led's... u could hook them up with your turnsignal or use them with some other type of switch if u want... depends how u want to use them....
i think ill wire the halos up to the parking lights because is it leagle to drive with just halos on
or if i wire it up to a switch i would use thisnspool of 18 4 i got
Thanks
Morninman
Thanks
Morninman
Originally Posted by biancoxb
I am trying to hook it up to a switch with some 12 v wiring , but no clue where to begin, anyone have photos ? or some advice where to look ?
