Free play in clutch ?
Old Jan 15, 2006 | 01:27 AM
aoshi12345's Avatar
Default Free play in clutch ?
Anyone else's clutch have like 1inch free play? I step on the clutch and there is no resistance for about an inch. Do I need to get this adjusted? Help plz.
Old Jan 15, 2006 | 12:43 PM
zer0's Avatar
Please Search, there is an article on here about "Clutch Stop" mod. I hear it works wonders. Just search for that.
Old Jan 15, 2006 | 08:54 PM
aoshi12345's Avatar
No dude...that mod is to remove free space below the enagement point. My problem is when the clutch is fully up and you press down on it. There is like 1 inch of no resistance. I beleive it is somethign to do with air in the clutch cylander. Ill check this out at the dealer.
Old Jan 18, 2006 | 06:49 PM
Tcjake's Avatar
mine does the same thing. i'd be curious to know if it is normal of if there's a problem. I've had my car about a month now and I just started to notice it. it may have been like that all along tho.
Old Jan 18, 2006 | 10:21 PM
zer0's Avatar
Its normal...
Old Jan 28, 2006 | 12:08 AM
SuperWhiteTC450's Avatar
Mine does the same thing, and there only seems to be two inches where my clucth actually engages and then I have the free play behind the clutch engagement.
Old Jan 28, 2006 | 12:52 AM
stl_tc_king's Avatar
check your spring too.
Old Jan 28, 2006 | 01:05 AM
stl what springs would you be talking about? I only have 320 miles on my car so the clutch is about as good as it will ever be.
Old Jan 28, 2006 | 01:28 AM
TimmyT's Avatar
Scion Society
.. Umm Most of the manual transmissions I have driven have free play before it nears the friction point. I would say its normal.
I take that back. There is always some sort of tension. I guess you are talking about NO resistance at all when you depress the clutch pedal for the first inch or so?
Then that could just be an adjustment.
Old Jan 28, 2006 | 02:18 AM
nodsetse's Avatar
Correct. Anyone who feels it's an issue can go to the dealership and have the freeplay adjusted. It's also fairly easy to do yourself, on just about any vehicle.
tcer904
Aug 30, 2024 12:49 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
