Catback for xB really short?
Old Jan 16, 2006 | 05:58 PM
NVFirefighter's Avatar
Default Catback for xB really short?
I saw some pictures of a catback and they look really short....axle back would have been my guess...flared at the cat end.
Also,can you use a header and catback leaving the middle/cat stock??
Thanks!
Old Jan 16, 2006 | 06:32 PM
blitz_xb's Avatar
yes a cat-back bolts to the back side of you cat and a header bolts to the front part of the cat
Old Jan 16, 2006 | 08:08 PM
JSosa's Avatar
ok here is the explanation. For our cars NO ONE is making a cat-back because the muffler is welded onto the cat at both ends. The only part of our exhaust that can be bolted on is a different muffler. As for the header, it is a simple bolt-on and it attaches to the first part of "tube" that connects to the resonator which in turn connects to the cat and the you have another little "tube" that connects to the flange of the axle-back.
So to say it more simply:
header - flange - tube - resonator - tube - cat - tube - flange - axle back
At the flnage points is where most of the aftermarket equipment bolts on. So what i did was eliminate the last: tube - flange -axle back section, and replaced it with an aftermarket axle back (InVidia, mad props, very nice) and had my local muffler shop weld a connecting "tube" (2 inches) from my cat to my axle back and eliminated the flange. So you could say my car is a catback and everything after the header and before cat is stock.
Old Jan 16, 2006 | 08:10 PM
JSosa's Avatar
My car:
header (DC Sports) - flange - tube - resonator - tube - cat - catback
If you combine this with a nice intake you will have a good HP gain in the whole RPM range.
Old Jan 16, 2006 | 08:21 PM
blitz_xb's Avatar
i talked to zero-1000 earlier this month and they said their are coming out with a cat back late jan early feb
Old Jan 16, 2006 | 08:53 PM
jrincon17's Avatar
Default UMMMM CATBACK
UMMMMM magnaflow has a catback . Its the only one , they cut from 2"s past the cat .
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
airmankevin1
Nov 17, 2015 05:44 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
