whats needed to lower my Xb
Old Apr 28, 2004 | 05:39 PM
H8_2LUZ's Avatar
Default whats needed to lower my Xb
I was thinking about lowering my xB on goldlines. Do I need anything else like a camber kit? Or can I just get it aligned w/ no porblems? I know I could always upgrade my struts but the stockers only have 200 miles on them so Ill just kill those first. Thanks
Old Apr 28, 2004 | 05:41 PM
randode's Avatar
Wagonistas
you only need the springs. the goldlines are a good choice. probably the best bang for the buck.
Old Apr 28, 2004 | 05:50 PM
scionspecialistvegas's Avatar
If yougot goldlines, Randode How to, then a jack, jack stand some wrenches a rachet and sockets and about 1 hour and it done, no camber kit, no alignment and you will sell the car before the shock struts wear out. be sure to cut your rubber snubber 1". The snubber are on top of the strut and look like a top hat. Thats all you need
Old May 20, 2004 | 12:44 AM
-Keith-'s Avatar
Same go for tein tech-s springs?
Old May 20, 2004 | 12:47 AM
dinkjs's Avatar
Yea pretty much
Old May 20, 2004 | 01:48 AM
MyBoX's Avatar
Bill, I read somewhere in this forum if I cut the snubber all the way, will get better ride, is this true? Sean
Old May 20, 2004 | 01:58 AM
Orataro's Avatar
sIcKsCiOnS
What's needed to lower your xB?
Best and easiest way is to take the air out of your tires. J/K
I have Goldlines and I love them. You'll love them too!
Old May 20, 2004 | 04:45 AM
Sean, that is a good question. no, cut then 2 inches max, i cut mine 1 1\2 inches helps the ride quite a bit. It is like hard foam, I used a filet knife to cut them. Bill
Old May 20, 2004 | 07:11 AM
MyBoX's Avatar
Thanks for the info Bill, Sean
Old May 20, 2004 | 10:26 PM
-Keith-'s Avatar
Lowered mine 2 inches. I cut thr front foam stoper just about a inch... (the bottom rung) Ride is so nice and I dont even bottom out on the deepest bumps!
Old May 20, 2004 | 10:29 PM
JdMBboFSD's Avatar
Default ummm...
can i get some specs on those goldlines and teins? and also if yall got hooks or got a good price on them let me know. I wanna lower my box really soon.....Thank you....
Old May 20, 2004 | 10:47 PM
-Keith-'s Avatar
Default Re: ummm...
SPECS....
http://tein.com/scion.html
Look at the tein s-tech springs.
As for hook up let me know when you are intrested in buying and I will pull some strings.
Old May 21, 2004 | 12:45 PM
Pulse's Avatar
N.G.S.O.
You'll also need a torque wrench and the torque specs for all the bolts/nuts.
Speaking of which, anyone have the specs? I'm gonna be needing them soon.
Old May 21, 2004 | 01:02 PM
scionmilktruck's Avatar
What happens if opt not to cut the bump stops???
Old May 21, 2004 | 03:03 PM
randode's Avatar
Wagonistas
i dont cut the bumpstops, and have never felt it bottom out.
Old May 26, 2004 | 11:45 AM
CBSIMONSEZ's Avatar
I installed the Tein H series and didnt cut my bump stops either. I have never bottom out. One good thing about the H series, they dont slame your ride to the ground. Dont believe me, take a look at my pics in my sig.
Old May 26, 2004 | 07:16 PM
TheScionicMan's Avatar
Bumpstop info from Gold-Line:
http://www.goldlineonline.com/installation_tips(10).htm
Old May 26, 2004 | 09:09 PM
-Keith-'s Avatar
I just did the S-tech and it isnt slammed... Look in the registry for my pics...
TheTripleC
Jan 4, 2015 06:46 PM
rancur3p1c
Dec 19, 2014 04:30 PM
SkateVandal
Scion xB 2nd-Gen Wheel & Tire
Nov 27, 2014 02:34 AM
XB_2
Nov 23, 2014 02:48 PM
Hardhitten
Nov 2, 2003 08:29 PM
